Blendigo for v1.1.13
enricocerica
Post by enricocerica » Mon Nov 10, 2008 6:41 am
Two things :
Opening an existing scene, the emitter definitions are lost and should be redefined. Could it be possible to keep them and to convert them automatically ?
It seems that UV data are not (or not always) transmitted correctely, don't know exactely in what context but I obtain different results with blendigo 1.1.7 and 1.1.13 over the same indigo version 1.1.14. I'll give you more info as soon as I can identify them. Does somebody else meet the same problem ?
Thanks again
SmartDen
Post by SmartDen » Mon Nov 10, 2008 7:55 am
i redefined the UV export, and as it seems to be wrong :(
Check normals, dude!
afranx
Post by afranx » Mon Nov 10, 2008 10:59 pm
I've a error in a scene with lights IES,
This scene worked well e now...
Fatal Error: IndigoDriverExcep: SceneLoaderExcep: ObjectExcep: transformation matrix is not invertible (In element 'model', around line 2711, column 5)
Stopped.
can you help me?
thanks for all SmartDen the script is very good
edit:
oops
worldscale 0.1 *10^0 error
worldscale 0.1 *10^1 ok
problem solved
SmartDen
Post by SmartDen » Tue Nov 11, 2008 1:50 am
have anybody else such strange behavior of blendigo?
Gog
Post by Gog » Tue Nov 11, 2008 2:59 am
SmartDen wrote:have anybody else such strange behavior of blendigo?
Not exactly, I have issues on one machine where the I/F partially re-draws so you get some buttons from an old tab and some from a new but nothing quite like what you are showing. I also put it down to that machine being a laptop using an intel graphics chipset :oops:
Olis
Post by Olis » Tue Nov 11, 2008 5:32 am
I get this strange error:
Should I post the scene?
Your lights stand no chance against the Indigo sun!
SmartDen
Post by SmartDen » Tue Nov 11, 2008 7:50 am
Olis wrote:I get this strange error:
yep, it could be helpful
Rhys
Post by Rhys » Tue Nov 11, 2008 5:04 pm
YES! i have seen that almost all the time. restarting blender fixes it but its annoying, i hoped i wasnt the only one. You know it also happens with yafaray and pretty much every other python script in blender to me. So it might be due to a new blender because it dont remember it before 2.48?
Is it with you also when you go over the button with the mouse, the button reappears and goes away when you press something?
Harry Beaver
Post by Harry Beaver » Wed Nov 12, 2008 4:30 am
First of all thanks to SmartDen for this update, but I too get some errors on older scenes that worked with previous belndigo versions:
- UV maps are stretched out
- I get the same error as Olis (above in this thread)
- I get also this error on some scenes
Fatal Error: IndigoDriverExcep: SceneLoaderExcep: ObjectExcep: transformation matrix is not invertible (In element 'model', around line 1699, column 5)
What does this mean ?
Cheers
SmartDen
Post by SmartDen » Wed Nov 12, 2008 4:38 am
Harry Beaver wrote:Hi,
1. UV maps are stretched out
2. I get the same error as Olis (above in this thread)
3. I get also this error on some scenes
Cheers
1. working on it
2. waiting for example scene
3. i guess you have instances in you secene. i'm remaking this part
EDIT BTW i have no issue this UV - maybe you post it too[/i]
Harry Beaver
Post by Harry Beaver » Wed Nov 12, 2008 9:03 am
Hi SmartDen
About my previous post some examples:
1. see attached images (BI & Indigo)
2. try this scene: Challenge #17: Natural History
3. this is one example (attached blendfile)
boolean.zip
(64.32 KiB) Downloaded 308 times
SmartDen
Post by SmartDen » Wed Nov 12, 2008 11:54 am
Harry Beaver wrote:Hi SmartDen
@1 i think your UV mapping is wrong
@2 fixed. i need some more tests and i'll release it
@3 look in you World Scale settings ;)
Harry Beaver
Post by Harry Beaver » Wed Nov 12, 2008 7:35 pm
Hi SmartDen,
@1. Could be, but in Lux it shows up well, I'll look into that one again
@2. Great news!
@3. Oops, guess I rushed a little bit, :oops: my bad, sry
SmartDen
Post by SmartDen » Wed Nov 12, 2008 8:50 pm
Hey, i don't care what Luxrender does. Just check your UV map.
Post by StompinTom » Thu Nov 13, 2008 5:39 am
i also had some issues with textures not being mapped properly. ill post an example once i can grab it from home.
