Coming Soon: ISLPreviewer
Hey MSUdom5...
I have the same Problem like Kram, and my output is:
"Der Befehl "java" ist endweder falsch geschrieben oder konnte nicht gefunden werde."
what means in English:
"the command "java" is written wrong or couldn't be found"
I just installed the latest Java package, but could find any 64bit version for windows :/
IMac with Windows Vista 64 Ultimate with an integrated chipset ATI Mobility Radeon HD 2600 XT (chipset shouldn't be any issue, playing here Fallout 3 without any Problems atm ^^)
Well, there really isn't an installer for the app. It's just a batch file launching the jar file and manually adding the jogl libraries to the library path.
ZomB, if java isn't in your windows path, you might need to manually point to the java executable by editing the batch file. I don't know why Windows wouldn't see it after installation, but then again, it's Windows.
Kram: I've never seen that behaviour before.
When you execute from the console, no output is generated? It just gives you a prompt again?
Sorry you guys are having trouble, but this testing is going to help me get all the kinks worked out, so thanks.
after doing as eman told I get this output:
Microsoft Windows [Version 6.0.6001]
Copyright (c) 2006 Microsoft Corporation. Alle Rechte vorbehalten.
So I tried to open the ISLPreviewer.jar with the Java.exe from "C:\Program Files (x86)\Java\jre6\bin" having this output:
C:\Users\Zom-B>a\64.bat
C:\Users\Zom-B>java -Djava.library.path=.\lib\win64 -jar.\bin\ISLPreviewer.jar
Unable to access jarfile .\bin\ISLPreviewer.jar
C:\Users\Zom-B>Code: Select all
C:\Users\Zom-B>a\bin\ISLPreviewer.jar
Exception in thread "main" java.lang.NoClassDefFoundError: C:\Users\Zom-B\a\bin\
ISLPreviewer/jar
Caused by: java.lang.ClassNotFoundException: C:\Users\Zom-B\a\bin\ISLPreviewer.jar
at java.net.URLClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
Could not find the main class: C:\Users\Zom-B\a\bin\ISLPreviewer.jar. Program will exit.
C:\Users\Zom-B>polygonmanufaktur.de
*trying*...
Edit: WOOT, WORKS! AND even the x64
And after two secs of trying around XD :
Minor Bug: When the window goes down to the taskbar and up again, the preview is gone. You need to click "update preview" that it shows up again...
VERY minor, though ^^
An other one (well, this time not even a bug): could you make tab jump only 4 spaces or so? The jumps are huge and it's somewhat nerving to hit space x-times for getting nice forms...
Great sofar!
Great sofar!
Users browsing this forum: No registered users and 46 guests
