- 3D Software: SketchUp
by Pibuz » Mon Nov 10, 2008 12:59 am
Hi guys..
Sorry to bother you..
It's been a while since i've been starting trying to achieve a realistic cor-ten material, but it seems like i'm ridiculously bad at that..
Somebody has some good textures and/or advices and/or ready materials so i can start messing around again? I'm in no hurry about that, that's only a sort of mania...
Thank you so much!
by CTZn » Mon Nov 10, 2008 2:59 am
Given
that image, i'd say a blend of two mats would do: rust and steel (quite matte of a steel tho), blended by a uniform noise map, where rust would cover 80% of the material at least.
the isl shader should not be too complicated too:
2 fbm's > remap colors to steppy fades (brown or gray, for rust or steel)
another hf noise func to mix'em. Theory rocks
Onfame
by Onfame » Mon Nov 10, 2008 4:01 am
i tried it with two textures blended with an shader, and added a little bumpmap, if you think it´s good enough i can upload it to the material DB.
- aciercorten.jpg (62.15 KiB) Viewed 20503 times
by Kram1032 » Tue Nov 11, 2008 4:40 am
The second link (the first that doesn't need to be copied) doesn't work for me...
SmartDen
by SmartDen » Tue Nov 11, 2008 4:47 am
Onfame wrote:i tried it with two textures blended with an shader, and added a little bumpmap, if you think it´s good enough i can upload it to the material DB.
Upload!
Check normals, dude!
Onfame
by Onfame » Thu Nov 13, 2008 11:36 am
Uploaded it but for better realism combine it with a dirt map or something.
by CTZn » Fri Nov 14, 2008 2:41 am
Onfame wrote:Uploaded it but for better realism combine it with a dirt map or something.
One can just use the two images I linked last in my previous post (rust_2k
x).
