Thanks. But i'm not very happy with modeling and lighting. maybe i'll done it once...zsouthboy wrote:I love it, Smart. Looks good!
Hurray for the site being back up!
Just thought I'd share this unfinished project. I set up the scene in a stupid way and there's a bunch of things I changed in the pose and model since this rendering. Nevertheless, I'll probably never finish this so a simple render will have to do.
As for any comment: 'What hitchhiker? What guide? Marvin who?'
- Some 4000 samples. Can't remember.
- DepressedAndroid.jpg (66.32 KiB) Viewed 5098 times
Over the Days the site was down I also tried to do something new andfinaly started to play around with Bodypaint, for a simple Kitchen-close-up scenario I got in my mind...
The Oranges aren't as good as they could be...contrast in my source images for the texture was lacking :/
Also I wait for the next Cindigo version for proper Blend fix so I could get better contrast between reflecting & non reflecting areas...
The Applecutter isn't finished jet, but I tried for some shading so far.... the plastic cap uses glossy transparent material with SSS and an exponent Map for the "dirt"
- 3 slightly different texture versions, all done in Photoshop, based on the middle original Bodypaint output...
- apples.jpg (47.71 KiB) Viewed 5088 times
- applecutter.jpg (88.97 KiB) Viewed 5088 times
- Still a lot of fireflys around... a phong issue??
- oranges.jpg (81.71 KiB) Viewed 5088 times
- PureSpider
Messing with code, and making an example render for the Clay material.
Model from http://www-graphics.stanford.edu/data/3Dscanrep/
- thai_statue.jpg (83 KiB) Viewed 4888 times
