Maybe for a future release, it could give you some hints on how to fix these errors?
Indigo fatal error
Indigo fatal error
It says that it found an unexpected element in "lens shift shift up distance" in the camera element.
@neoO
on behalf of all labouring export writers I have to say that is a useless post
I get tired of seeing these one line descriptions of errors and people expecting to get effective help from that
if you really think you have an issue in the first instance reply to your exporter forum stating some helpful information like what versions of the exporter and indigo you are using etc.
if you are quoting correctly there, there is a mistake in that exporter in that 'shift' is stated twice
it is up to the exporter writer to fix that or alternatively if you want in this case, open the .igs in Notepad and edit the line with that in it to look like this
note that I quoted both shift statements in case they are wrong
please think about what you are posting
how high is a chinaman...
<lens_shift_right_distance>0.000000</lens_shift_right_distance>
<lens_shift_up_distance>0.002000</lens_shift_up_distance>please think about what you are posting
Sorry, but that's because the error was a one liner too.
Indigo version : 1.9.02
Skindigo Version : SkIndigo 1.1.8
Basically, latest versions of both.
I read in the sketchup forum, that 1.1.8 was compatible with the latest v of indigo
- its been a bitter past.JPG (21.96 KiB) Viewed 10875 times
well there you go - you didnt even quote the error correctly let alone tell us what you were using
now we know that much I'll let a Skindigo user answer it
cheers BF
EDIT:
ok wait I've got my good samaritan hat on and actually I see at the bottom of page 1 of the Skindigo1.1.8 thread what appears to be exactly the same error and on p2 the solution. wow! what a bit of luck
cheers BF
EDIT:
- PureSpider
neo0. wrote:Sorry, but that's because the error was a one liner too.
May I slap him please? I mean finally he deserves it somehow
Im sorry, you're not helping at all CTzn.PureSpider wrote:neo0. wrote:Sorry, but that's because the error was a one liner too.
I read in the sketchup forum, that 1.1.8 was compatible with the latest v of indigo![]()
- PureSpider
Guy it's been told like a THOUSAND times that you only should use the corresponding versions of the exporter and indigo...
How could Indigo 1.0.9 recognize commands first introduced in 1.1.8 or even later?
It's like... trying to read DVDs with your CD player and wonder why it won't work -.-
I'm just that upset 'cause you ask the same questions that have already been answered sufficent times over and over again...
USE THE BOARDS SEARCH GODDAMNIT!
- PureSpider
I have the same problem as neo0. I am using SkIndigo 1.1.8, which is reported to work with Indigo 1.1.9, which I am using. I would appreciate any possible help. The only line containing "lens_shift_up_distance" in the Ruby script is as follows:
Thank you.
out.puts " <lens_shift_up_distance>#{@irs.shift_up.to_f/1000.0}</lens_shift_up_distance>"
out.puts " <lens_shift_right_distance>#{@irs.shift_right.to_f/1000.0}</lens_shift_right_distance>"
out.puts " </camera>"
