SkIndigo 1.0.9 Official
cpfresh
Post by cpfresh » Tue Sep 09, 2008 6:30 am
are your faces pointing the right direction?
Wiz
Post by Wiz » Tue Sep 09, 2008 11:18 am
hi,
im not sure what you mean? when i send it to render i am facing the area i want to render, its odd though that some of the glass is renderd and not other bits?
if you could let me knwo what you mean by faces i would be very grateful, ive only just started using indigo and sketch up..
many thanks
cpfresh
Post by cpfresh » Tue Sep 09, 2008 11:49 am
oh ok. the easiest way to check your face orientation is by using the 'monochrome' render method in sketchup. there will be two colors displayed a 'front' color and a 'back' color. make sure all of the 'front' faces are pointed outward of the geometric shapes and visible by the camera. hope that helps.
Wiz
Post by Wiz » Thu Sep 11, 2008 2:47 am
Thank you ssoooooo much!!!
ive been having this problem for a while, thanks alot for your time and advice.
crojack
Post by crojack » Tue Oct 28, 2008 4:57 am
Does anyone have this available for download? I foolishly got rid of it and the download on the site isn't available anymore.
Thanks!!
crojack
Post by crojack » Tue Oct 28, 2008 5:55 am
Found it, maybe the link has changed?
http://www.indigorenderer.com/joomla/in ... &Itemid=98
Lander
Re: SkIndigo 1.0.9 Official
Post by Lander » Tue Jun 02, 2009 2:08 pm
I have a problem with the installation on mac.
After the initial request of locating the indigo.exe file... I must remember that there is no .exe files on mac... I select the indigo.app as file path and then SU sends me another message:
Error Loading File SkIndigo_1_0_9.rb
Permission denied - /Users/User/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/indigo_1_0_9path.txt
I checked my permissions and they are allright
If I put the .rb file and folder in the plugins of the general library instead the user library I get this message:
can't convert nil into String
So I suspect I'm getting this problem because I'm installing files in the bad folder but there are 3 or 4 folders that SU can call to look for plugins.
CoolColJ
Post by CoolColJ » Thu Jun 11, 2009 12:26 pm
Download link nolonger works :(
Post by Whaat » Thu Jun 11, 2009 3:36 pm
CoolColJ wrote:Download link nolonger works :(
http://www.indigorenderer.com/dist/plug ... -1.0.9.zip (or go to the Downloads Page) :)
Post by Whaat » Thu Jun 11, 2009 3:40 pm
Lander wrote:I have a problem with the installation on mac.
Sorry Lander, I missed this post. SkIndigo 1.0.9 does not work on Mac. I am currently working hard to make the next version (2.0.X) fully Mac compatible.
