Cindigo 1.1.10 Beta
Cindigo 1.1.10 Beta
Post by fused » Wed Sep 10, 2008 6:01 am
Cindigo 1.1.10 Beta
for Indigo 1.1.10
download exporter:
PC Version
(or below)
The file contains PC versions for R10 and R9. (R10 users will have to rename the "cindigo1.1.10.cdl_R10" to "cindigo1.1.10.cdl")
Make sure you have the newest version of quicktime installed!
Good beginner tutorials can be found here (german and english, a bit outdated)
1.1.10 changelog:
* added .igmesh export. reduces export time drastically
* added emission_scale (find it under tags-> emission normalization tag). you need to assign the material on the objects which should be scaled to the tag, as objects can have multiple mats)
Do you like Cindigo?
If you think its valueable software, please feel free to donate.
Please split the donation in two and donate the other half to Indigo.
Cindigo 1.1.10.zip
Cindigo 1.1.10
(3.05 MiB) Downloaded 479 times
lightnormtest.zip
emission_scale test scene
(16.33 KiB) Downloaded 371 times
Post by PureSpider » Wed Sep 10, 2008 6:04 am
thanks but... fill in the DL link :P
Post by fused » Wed Sep 10, 2008 6:09 am
:) yeah. ill add a sample scene for emission_scale, too. but somehow indgo 1.1.10 refuses to work properly,,,
oh, sth is wrong with the global scale... ill fix it.
Post by fused » Wed Sep 10, 2008 7:05 am
theres a rotation bug. ill fix it.
dont have any nerves for that now. tomorrow...
Post by fused » Wed Sep 10, 2008 9:10 pm
bug fixed. have fun.
mrmoose
Post by mrmoose » Wed Sep 10, 2008 9:15 pm
Great fused, now i'll test it :wink:
tungee
Post by tungee » Wed Sep 10, 2008 9:43 pm
Great Fused!
Does i have read right:
1 Object could have multiple Materials?
Thanx again fused!
Post by pixie » Wed Sep 10, 2008 9:48 pm
AFAIK it was always possible, but perhaps they couldn't overlap...
Post by fused » Wed Sep 10, 2008 10:03 pm
you can use multiple mats on an object using selection tags.
Pinko5
Post by Pinko5 » Wed Sep 10, 2008 11:04 pm
Wooowwwww tnx Fused!!!
Luca. ;)
Post by pixie » Wed Sep 10, 2008 11:12 pm
It's fast, Fast, FAST!!!! :twisted:
Post by pixie » Wed Sep 10, 2008 11:32 pm
Luminous Flux was first introduced in Indigo 1.1.6
Post by fused » Wed Sep 10, 2008 11:33 pm
well, yea. just didnt have the time to put it in the last release.
Post by pixie » Wed Sep 10, 2008 11:39 pm
I've just referenced it because light normalization give little info when being searched in the forum, and it isn't also on the manual, this way people can find a bit more about this new feature.
More references:
Efficacy scale
The ‘power drawn’ is over the whole emitter surface, not per unit area. So a bigger mesh area or a scaled one with the same setting means comparatively less light output as seen by the observer. For ‘uniform’ emitters the spectral radiance values to use will be quite large - say 10^8.
tony
Light Intensity
Luminous Emittance
carsten_fokuspunkt
Post by carsten_fokuspunkt » Thu Sep 11, 2008 4:03 am
Thanx a lot for this version, fused. i just played around with multi-materials on a mesh via selection-tag and this is soooo cool.
