"Backbody Light Materials are currently not supported by this feature"
I have the newest Indigo and Skindigo and trying too make some windows glow for a dusk shot render.
Could anyone explain what the best way to do this is, or tell me why it says the material isnt supported by the feature when I go to the Skindigo material editor
Thanks
Im am not familiar with skindigo code or what you are doing but at a guess he is meaning the old emitter types (blackbody,rgb, peak) for meshes -handily referred to as a 'material' when you apply them- cannot have the new 'emissive' function as well. meshlights are different.
if you want to make the glass itself glow I would think you should choose a specular transparent material (is there a glass preset?) and give it some emission (glow). ie dont try to use a meshlight for its 'material'.
HTH
HTH
Yes im trying to make the glass glow, or have a light source glow from behind the glass.
Still figuring SKIndigo and experimenting on how to add a glow to a surface; I had thought indigo worked off materials where you change the setting for the particular material on the surface ie glow reflection etc
So I made a surface behind a Skindigo preseted glass and applied a raw color as the material to the surface, then again using the skindigo material editor applied the preset backbody light and RGB with luminous of 300 behind the glass. Still no glow.
Any comments on how hard im making this would help a bunch.
Thanks
Thanks
