Hi All,
I'm writing an exporter for my CAD Application to Indigo Render.
Currently I'm only using B&W (more or less) diffure material but I want to use textures (see my test image and see original scene http://www.youtube.com/watch?v=p3EzCgTEwRU).
In my Application texture attributes (gain and offset) are related to materials and not to objects. Each object has its UV set but is the union of Material UV attributes + Object UV coords that defines the final mapping of a texture onto surfaces/objects.
Is there something similar into Indigo scene language ? Can I use the tag <u_scale> (or <v_scale>) inside the tag <albedo_texture>?
Regards
Delle
Help to define Texture coordinates
- Test image
- im1219249102_Finale.JPG (45.97 KiB) Viewed 40402 times
Hi Delle,
there are no <u_scale> or <v_scale> parameter inside any tag referring to texture in indigo scene description. Inside the <albedo_texture> tag, for example, the only reference to UV values is the <uv_set>. Adjusting the UV values exported during the mesh creation process you can properly "scale", "move" or "rotate" your UV coords.
Hope this helps, R.
Hope this helps, R.
Hi R. Gigante, I know that I can use uv_set during mesh creation process but, in my case, I prefer to change materials/texture mapping into igs file directly without re-export all (I'm currently testing Indigo materials).
In addition to this, I use many textures with different mappings for the same material. This force me to create many uv-sets for all objetcs.
....maybe adding a little gain/offset feature to Textures could help
Delle
Delle
