Indigo 1.1.9
v_mulligan
Post by v_mulligan » Fri Aug 22, 2008 3:32 am
Any thoughts on fixing the UV seam issue with subdivision surfaces identified in 1.1.8 and previous releases?
Deus
Post by Deus » Fri Aug 22, 2008 10:40 pm
No but Ono promised to remove ugly colored dice atleast.
Post by pixie » Fri Aug 22, 2008 11:36 pm
:lol:
MSUdom5
Post by MSUdom5 » Sat Aug 23, 2008 3:39 am
v_mulligan
I've had the same problem. (Using Blender/Blendigo.) The problem occurs when I use "Set Smooth" on a mesh (not sure what the setting is in SoftImage). The only way I could work around it was to turn off "Set Smooth" and increase my number of subdivisions.
What happens if you UV Map a plane and use subdivision surfaces? Do you see mapping problems?
v_mulligan
Post by v_mulligan » Sat Aug 23, 2008 4:40 pm
Deus wrote:No but Ono promised to remove ugly colored dice atleast.
Ha ha! Yes, I forgot -- 1.1.9 comes with the <nodice> XML tag.
v_mulligan
Post by v_mulligan » Sat Aug 23, 2008 4:46 pm
MSUdom5 wrote:v_mulligan
Yes -- the equivalent in the XML file is the subdivision smoothing option, I'm guessing, which is what triggers the problem. If you do the subdividing before exporting, you're fine -- but that defeats the purpose of doing subdivision at render time. Plus, you need the rendertime subdivision for rendertime displacements.
If you UV map a plane and turn on subdivision, it's fine. It's just seams -- i.e. places where the U or V values change discontinuously -- that are the problem. See the bug thread for details.
Incidentally, this is NOT a Softimage exporter issue. I'm adding the subdivision tags by editing the file manually.
v_mulligan
Post by v_mulligan » Sat Aug 23, 2008 5:22 pm
Incidentally, I just checked. The scene renders identically in 1.1.9 as it did in 1.1.8 -- same artefacts at UV seams on subdivided meshes.
filippo
Post by filippo » Thu Aug 28, 2008 12:49 am
as I can assign a layer blendig to emitter object?
filippo "radiosity"
Big Fan
Post by Big Fan » Fri Aug 29, 2008 6:33 pm
hey I'm testing my script and IES lights arent working - the code works in 1.0.9 but not 1.1.x
has anyone else noticed this or is it something I am missing/messed up? (again) :wink:
EDIT
finally got back to this today - and it works! (same file) - odd indeed...
there must be a glitch somewhere in there I stumbled on - unfortunately I overwrote the problem .igs so I'll guess I'll have to wait to rediscover it :roll:
so you can all stop looking now :lol:
Big Fan
Post by Big Fan » Mon Sep 01, 2008 11:10 pm
hmmm the issue appears to be related to using the Indigo UI
It seems it renders a scene only initially using IES and then as black in instances after that. weird :?
The console mode seems to work all the time..same file output from blendigo in each case
a bug for ono?
Post by OnoSendai » Sun Sep 07, 2008 7:06 pm
Phr0stByte wrote:Very exciting! Maybe us Linux purists (Ono's bald-headed step children) will get a some linux builds next version - wow - 1.2.0! Will next build be the one? I will wait with baited breath - still stuck on 1.0.9.
Linux builds will be made for stable major releases (eg. for 1.1.x when it stabilises)
Post by OnoSendai » Sun Sep 07, 2008 7:07 pm
v_mulligan wrote:Any thoughts on fixing the UV seam issue with subdivision surfaces identified in 1.1.8 and previous releases?
Nope, I'm not sure if it's solvable, at least given the current information passed in the mesh format.
joegiampaoli
Post by joegiampaoli » Sat Dec 27, 2008 8:59 am
will delete last messages, seems like it was a bot. :?
Joe Giampaoli
My Indigo Gallery
Users browsing this forum: No registered users and 86 guests
