Coreyrn
by Coreyrn » Tue Aug 19, 2008 5:30 am
First I'm new so "Hello"
I installed Blendigo 1.1.7 and Indigo 1.1.7 and tried to export a scene.
But after a few Ignoring degenerate triangel messages an error occured.
No such uv set 'uv'
I use many uv textures in my scenes but this error never occured to me before. How can I fix it or locate the source of the problem?
Coreyrn
by Coreyrn » Tue Aug 19, 2008 7:54 am
Thanks. But it only helped partly.
Now there occures near the same error.
Fatal Error: IndigoDriverExcep: SceneLoaderExcep: No such uv set 'UVTex'
Stopped.
I wrote UVTex into every line where it is needed, checked three times.
What have I done wrong?
Lord of the Rings Junkie
by Lord of the Rings Junkie » Tue Aug 19, 2008 8:34 am
Basically what you want to do is make sure that the UV sets the meshes are using and the UV sets Blendigo is using have the same name. I just assumed you left your UV set as the default name, 'UVTex'.
Coreyrn
by Coreyrn » Wed Aug 20, 2008 12:03 am
Ok, I worked it out and now it's rendering.
Thank you very much for your help
