Tire Rubber
Lord of the Rings Junkie
Tire Rubber
Does anyone have a good suggestion on what sort of SSS settings to use for black rubber? (Like you might see on car tires or toilet plungers.)
I already know the color should be very dark (0.1, 0.1, 0.1), I just need to figure out what SSS values would be realistic.
- Borgleader
well zuani did an incredible job making his tires. maybe you could ask him?
http://www.indigorenderer.com/joomla/fo ... php?t=4374
Scroll down a bit theres a close up render of a tire.
Hope this helps
(you're not making a MALP are you?
Hope this helps
Yes amazing images from zuani ! But if he had used sss that would have been noticeable on fine features at leastBorgleader wrote:well zuani did an incredible job making his tires. maybe you could ask him?
Not a MALP, but it's sci-fi related.
'Plunger' should be a big hint.
I honestly have no idea what these SSS values mean, I've only ever used them before to get a foggy room... Could someone point me to a crash course on SSS? I looked in the manual, but it wasn't very clear to me. Perhaps I will give Zuani a PM. I just want it to look a LITTLE bit softer than that tire rubber.
Unfortiunately, there really isn't a materia;l guide. The indigo manual mainly covers the xml, but that isnt useful for people who use the ui...Lord of the Rings Junkie wrote:Not a MALP, but it's sci-fi related.'Plunger' should be a big hint.
- Borgleader
