cpfresh
by cpfresh » Mon Aug 18, 2008 4:30 am
i think you just need to remove the uv_expose information that isnt used ...
Bogey Jammer
by Bogey Jammer » Mon Aug 18, 2008 4:54 am
But i must be used
My mesh has two UV sets
Indigo 1.1.11 32bit + Blendigo 1.1.7
My render supercomputer:
- Acer aspire 5612Zwlmi
- Intel T2060 dual core 1.6 GHz
- 1GB RAM
- vista home premium 32bit
Big Fan
by Big Fan » Mon Aug 18, 2008 11:46 am
look here
Blendigo still needs some things updated re uv for the latest Indigo version
Just be patient for smartden to come back from holiday and catch up
Please use the last good versions of Indigo and Blendigo until that happens
Pinko5
by Pinko5 » Fri Aug 22, 2008 6:06 am
There is the possibility to use layers indigo with this version of Blendigo 1.1.7??
Tnx for reply
Luca.
Grimm
by Grimm » Sun Aug 24, 2008 12:38 pm
Bogey Jammer wrote:I also have this problem:
Fatal Error: IndigoDriverExcep: SceneLoaderExcep: ModelLoadingStreamHandlerExcep: UV set with index 1 was exposed, but the UV set data was not provided. (In element 'mesh', around line 7464, column 5)
I opened the igs file and there's actually no *uv1* line..
I had a similar problem. I had mixed up my mesh's when I duplicated some of them and the names were the same. Once I had made sure all of the names (the mesh/object name, texture name, and UVTex name) were unique, everything worked. I don't know if this is the same case for you though.
I think that both Indigo and Blendigo are more strict when it comes to naming.
Grimm
