WIP bathroom and question about exr
12 posts • Page 1 of 1
carsten_fokuspunkt
Post by carsten_fokuspunkt » Sat Aug 16, 2008 2:22 am
Hello everybody,
first i have to thank this cool community and of course "Ono" for this incredible piece of software and "fused" for cindigo. keep on guys!!!
This bathroom ist my first serious project with indigo. Rendered over night on three machines.
Does anybody know a software for tonemapping? Tonemapping with photoshop cs3 sucks and qtpfsgui dont want to tonemap this exr. Also i can´t open the igi file, created with indigo1.1.5, with violet or indigo1.1.7.
How to tonemap the rendered shots???
Thanks a lot!
Post by BbB » Sat Aug 16, 2008 3:02 am
I can't answer your question. Just wanted to say it's a damn fine image you got here! But get rid of the blurry leaves outside. They don't do the rest of the image justice.
carsten_fokuspunkt
Post by carsten_fokuspunkt » Sat Aug 16, 2008 3:21 am
thanks BbB! this blurry thing was to throw a blurry shadow in the room. Then its finished this "thing" will be replaced by a real sky...
how do you tonemap your renders? directly in indigo?
Post by CTZn » Sat Aug 16, 2008 3:39 am
One thing you can try is to resume the render with 1.1.7 in order to use the embedded tonemapping tools. Hopefully 1.1.7 will take the 1.1.5 scene without complaining...
carsten_fokuspunkt
Post by carsten_fokuspunkt » Sat Aug 16, 2008 3:42 am
i tried this, but 1.1.7 didnt want to render it :(
Post by CTZn » Sat Aug 16, 2008 3:55 am
Certainly 1.1.7 told you what was wrong; as far as I can see, your last chance would be to follow 1.1.7 (or later) instructions (in error messages) for editing the exported igs/xml.
Remove the unexpected, add the expected and at the end that could work... nevertheless try tonemapped exr output (as opposed to untonemaped), maybe qtblahblah will accept it better ?
Post by Borgleader » Sat Aug 16, 2008 4:07 am
that is one super cool bathroom, awesome work :)
Post by fused » Sat Aug 16, 2008 5:11 am
wow, impressive!
Post by Zom-B » Sat Aug 16, 2008 5:28 am
A great picture, even that BbB is right about the trees in BG... also the shadow of the plant in the lft seems very sharp, a softer one would please the nice atmosphere! Nice to see another cindigo user on the board.. welcome!
afaik 1.1.7 got this phong issue, should be fine with 1.1.9...
tonemapping via Indigo GUI atm doesn't work if you do networkrendering!
Simply after you are ok with the rendering, close indigo, start as normaly (not as working master) and resume your file, so you can tonemap your image :)
to get linear & camera working with exr (and the last cindigo capabilities!) raise the EXR gain to 1000000 and choose a very high exposure duration to get your exr bright enough for linear & camera tonemapping.
lowering the f-stop or the Focal length is also possible, but both have effect of your DOF, so take care!
Using Picternautfor tonemapping is also very easy! Make sure to save (un)tonemapped exr... or change this parameters in the igs file if you forgot, and resume the rendering!
Woodie
Post by Woodie » Sat Aug 16, 2008 7:03 am
One comment only to the design (renders is great). The shower base. It just looks odd. Much better would be custom one from tile matching the floor.
Post by neo0. » Sat Aug 16, 2008 7:11 am
Wow, that looks amazing. What did you use for your metal?
Post by Zom-B » Sat Aug 16, 2008 12:14 pm
neo0. wrote:Wow, that looks amazing. What did you use for your metal?
cr.nk
