Tire Rubber
10 posts • Page 1 of 1
Lord of the Rings Junkie
Tire Rubber
Post by Lord of the Rings Junkie » Tue Aug 12, 2008 5:55 pm
Does anyone have a good suggestion on what sort of SSS settings to use for black rubber? (Like you might see on car tires or toilet plungers.)
I already know the color should be very dark (0.1, 0.1, 0.1), I just need to figure out what SSS values would be realistic.
Post by Borgleader » Wed Aug 13, 2008 12:07 am
well zuani did an incredible job making his tires. maybe you could ask him?
http://www.indigorenderer.com/joomla/fo ... php?t=4374
Scroll down a bit theres a close up render of a tire.
Hope this helps :) (you're not making a MALP are you? ;))
Post by CTZn » Wed Aug 13, 2008 12:32 am
Borgleader wrote:well zuani did an incredible job making his tires. maybe you could ask him?
Yes amazing images from zuani ! But if he had used sss that would have been noticeable on fine features at least :? Vulcanised natural rubber is pretty opaque, in biased terms the scattering radius could even be under 1mm.
Post by Lord of the Rings Junkie » Sat Aug 16, 2008 3:52 pm
Not a MALP, but it's sci-fi related. ;) 'Plunger' should be a big hint. :)
I honestly have no idea what these SSS values mean, I've only ever used them before to get a foggy room... Could someone point me to a crash course on SSS? I looked in the manual, but it wasn't very clear to me. Perhaps I will give Zuani a PM. I just want it to look a LITTLE bit softer than that tire rubber.
Post by neo0. » Sun Aug 17, 2008 10:37 am
Lord of the Rings Junkie wrote:Not a MALP, but it's sci-fi related. ;) 'Plunger' should be a big hint. :)
Unfortiunately, there really isn't a materia;l guide. The indigo manual mainly covers the xml, but that isnt useful for people who use the ui...
Post by Lord of the Rings Junkie » Mon Aug 18, 2008 3:02 pm
Looking through Zuani's thread I found a screenie that seems to indicate that his tire material is just a low exponent phong with no SSS at all.
I think I'll tell you what I need this for now...
EXTER-MIN-ATE!
Post by CTZn » Mon Aug 18, 2008 3:14 pm
Oh nice ! I think I could have some use for in case my closets get obstructed...
Joking :D It's both nice and fun LotRJ !
Post by Borgleader » Mon Aug 18, 2008 3:19 pm
Wow man that is just amazing. Awesome work :) Although I expected no less, coming from the stargate maker.
Post by Lord of the Rings Junkie » Mon Aug 18, 2008 3:33 pm
Still need help on that SSS material though... :( Gots ta hav a rubber cup, nat a plastic won. :roll:
zsouthboy
Post by zsouthboy » Mon Aug 18, 2008 11:35 pm
Gorgeous render LOTRJ!
