Shader tests
Big Fan
Post by Big Fan » Tue Aug 12, 2008 7:02 pm
it would be cool to declare textures and shaders globally (keeping using the index thing) instead into a material,
God give me a break I only just did the index thing I dont need it redone already :evil:
How about we are just happy with what we have for a while
Too much more of this stuff and people burn out with exporter updating :roll:
Plenty of other things could get attention without getting convoluted in shaders - reminds of the tropical sea water adventure :)
Post by fused » Tue Aug 12, 2008 7:58 pm
okay, heres some colored gradient, im on a mac right now, so no chance to test it(maybe someone wants to give it a try?):
edit: they dont seem to work :)
edit: now they do
edit:dont work as expected, forget it :)
Post by fused » Tue Aug 12, 2008 9:05 pm
got it now: renders will follow soon:
<albedo>
	<shader>
		<shader>
			<![CDATA[
			# 2D colored gradient shader V
			def colorCalc(real x) vec3 :
				vec3(
					# color1 = red (0.75,0,0)
					# color2 = green (0,0.75,0)
					# compute color mix
					#  color1 \/                      color2 \/
					add(mul(0.75,x),mul(sub(1.0,x),0.00)),
					add(mul(0.00,x),mul(sub(1.0,x),0.75)),
					add(mul(0.00,x),mul(sub(1.0,x),0.00))
			def eval(vec3 pos) vec3 :
					colorCalc(dotj(getTexCoords(0)))
		</shader>
	</shader>
</albedo>
heres the z up gradient thingy with color:
<albedo>
	<shader>
		<shader>
			<![CDATA[
			# 3D colored gradient shader Z (up) with center = 0.5
				vec3(
					# color1 = blue (0,0,0.75)
					# compute color mix
					add(mul(0.00,x),mul(sub(1.0,x),0.00)),
					colorCalc(div(mod(add(dotk(pos),div(0.6,2.0)),0.6),0.6))
		</shader>
	</shader>
</albedo>
edit: just notced there was some color clamping going on in the 3d gradient. fixed now
Deus
Post by Deus » Tue Aug 12, 2008 10:38 pm
Still cool but useless images ;) Ill post something... (image shack messed image up bad)
here i used a shader that looks like this:
	<material>
		<name>land</name>
	      <diffuse>
  			<texture>
		            <uv_set>uv</uv_set>
		            <path>world.png</path>
				<exponent>1</exponent>
			</texture>
			<albedo>
				<shader>
					<shader>
						<![CDATA[
						# This is a comment
						def eval( vec3 pos ) vec3 :
					               sample2DTextureVec3(
					                  0,
					                     add(
						                     	mul(
						                     		vec2(
						                     	  		mul( cos(mul(noise(pos), 6.28) ) ,fbm(pos,10) ),
						                     	  		mul( sin(mul(noise(pos), 6.28)) ,fbm(pos,10) )
						                     	  , 0.001 )
						                     	getTexCoords(0)
					</shader>
				</shader>
			</albedo>
		</diffuse>
	</material>
It is used to preturb the texture coordinates slightly so I can get away with a much lower resolution for the ground without getting square looking patches. Look closely at the green patches on the beach. Looks pretty nice. Trees still looks like shit but I did reduce the beach "size" after suggestion from you guys :)
Oh while I am at it. Ono what is the ouput range of noise functions? 0-1? -1 - 1 ? 0-X? talking about noise/fbm
Cheers!
/ D
zsouthboy
Post by zsouthboy » Wed Aug 13, 2008 2:56 am
I like how Deus casually posts something awesome, like it's no big deal.
Post by Borgleader » Wed Aug 13, 2008 4:07 am
zsouthboy wrote:I like how Deus casually posts something awesome, like it's no big deal.
+1
He is one letter away from Zeus...so I guess awesome is normal for him :lol: :roll:
Lord of the Rings Junkie
Post by Lord of the Rings Junkie » Wed Aug 13, 2008 4:45 am
OnoSendai wrote:Another test:
(Piccy of brushed metal sphere)
Looks good as a bump test, but the shading is far from anisotropic. :( A true anisotropic shader would be awesome. :)
Deus
Post by Deus » Wed Aug 13, 2008 5:18 am
Oh thanks. It depends on who you are. I cannot model an ordinary vase properly.. math and programming I can do in my sleep. I envy most of you guys in this forum for your artistic skills :)
If you wanna steal ...err use the shader yourself preturb textures more then increase the 0.001 parameter (its the pertubation distance)
Post by pixie » Wed Aug 13, 2008 7:50 am
+1
You might not know but Deus is* God... ;)
*is as in means
Post by StompinTom » Wed Aug 13, 2008 12:02 pm
nah it really isnt a big deal. so 90s.
Post by CTZn » Wed Aug 13, 2008 3:26 pm
If you mean an anisotropic shader like in biased renderes, I don't agree. Or, as far as I'm concerned, you are not looking after a realistic effect :)
Post by fused » Wed Aug 13, 2008 6:28 pm
Deus wrote:Still cool but useless images ;) Ill post something...
whoa, thats cool!
Post by fused » Wed Aug 13, 2008 6:42 pm
some new output, trivial and not as cool as deus' but funky with displacement ;)
rendered as always by zomB
edit:
heres the mat:
    <material>
        <name>shader</name>
        <diffuse>
            <albedo>
                <shader>
                    <shader>
                        <![CDATA[
= 0.5
                            vec3(
                                # compute color mix
                            colorCalc(div(mod(add(dotk(pos),div(0.1,2.0)),0.1),0.1))
                    </shader>
                </shader>
            </albedo>
            <displacement>
                <shader>
                    <shader>
                        <![CDATA[
                        # ~1/3pi sinus waves displacment U
                        def eval() real :
                            mul(sin(div(mod(doti(getTexCoords(0)),0.1),0.1)),20.0)
                    </shader>
                </shader>
            </displacement>
        </diffuse>
    </material>
Deus
Post by Deus » Thu Aug 14, 2008 12:38 am
That was cool :) 1.1.9?
Post by CTZn » Thu Aug 14, 2008 1:00 am
Wondering: let's consider two special, but practical cases:
I must use a given texture for whatever parameter, but:
Case A: the texture I have is of a too too low x-y resoulution,
Case B: the pixel depth in the texture is too low (ie 8bit for displacement)
Can you see, for both cases, a way to improve the textures (dithering, smoothing, whatever) ? Provided that we would have better precision in UV space than just texture space (better results with shader than by photogimping).
I hope I wasn't too unclear, just trying to be prgmatical :)
Already, thanks !
Users browsing this forum: No registered users and 103 guests
