Camera clipping
5 posts • Page 1 of 1
doudou
Camera clipping
Post by doudou » Fri Aug 08, 2008 12:47 am
Hi all,
I'm trying to render an interior scene of a small room. I'd like to keep a camera lens of 35mm in order not to deform the image, but I have to go forward the wall !!!
A solution in 3DS or Blender is to make a camera clipping, see a example here : http://en.9jcg.com/comm_pages/blog_content-art-117.htm
So I can place my camera behind the wall and set the start clipping value just before the wall. Like that I don't have to modify my model to push the walls behind my camera !!!
I don't find any solution to set a clipping value to the camera in Indigo, and I don't know if it is possible.
Is there any way to achieve this, or could it be a new feature request ?
Thanks.
Post by fused » Fri Aug 08, 2008 1:12 am
no, this is not possible in with indigo.
rgigante
Post by rgigante » Fri Aug 08, 2008 6:43 pm
..but we can always cut your model :D
doudou
Post by doudou » Fri Aug 08, 2008 7:31 pm
Of course, but if I cut my model, I can't make other rendering form other point of view !!!
I need a model for each point of view.
Apollux
Post by Apollux » Sat Aug 16, 2008 11:54 am
Keep in mind that in reality you wouldn't be able to capture the image without cutting a hole in the wall or using a wider lens.
And yes, you can cut the model and still render from another POV, just put each wall on a separate layer and turn off the one you need for the current POV.
Users browsing this forum: No registered users and 67 guests
