how to make a laser?
I just built a parabol by hand and its much easer to get it in focus now! Was actually quite easy thanks to the spin tool.
edit:I put in the IES, its very simple, just look at it in texteditor
- laser.IES.zip
- its very simple, just look at it in texteditor
- (373 Bytes) Downloaded 309 times
- reduced brightness of linear tonemapping by one magnitude
- im1218032772.png (92.45 KiB) Viewed 5690 times
- Wall textured with this 2cm grid picture. 2cm = 0.2 Blenderunits, so the ray is about 0.3 units in diameter
- im1218032987.png (130.75 KiB) Viewed 5692 times
- Borgleader
v_mulligan
There are some in the New Testament, though I'm not a particularly big fan myselfalex22 wrote:Nice, how do you do the parable?
Cool! You just discovered spherical aberrationalex22 wrote:I tried it with an special IES and an squashed halfsphere as mirror, but I can't get it parallel, its always diverging a bit.
v_mulligan
v_mulligan
Umm... I'm not sure you're doing it right. Unless that paraboloid is a very, VERY dense mesh, you're probably just reflecting your light in a flat mirror.
What you really want to do is have rays coming from your source in a broad arc -- say, 45 to 90 degrees. These should then strike your paraboloid and reflect back so that they're parallel. The diameter of the laser beam will be approximately the diameter of the paraboloid, so you want to use a very tiny emitter, a small paraboloid, and a large scene.
v_mulligan
Here's what I meant. On the left, I've got a tiny hemispherical emitter at the focus of a parabolic mirror, with a small beamstop in front of the emitter to prevent it from flooding the scene. On the right is an ordinary cube. You can see the green beam reflected from the mirror is the same size as the mirror and it doesn't spread out at all. Pretty good laser, eh? All this needs is a little fog in the scene so that the beam is visible.
Incidentally, the laser is green, here. The red rods are not part of the laser setup -- they're just to add a little more illumination so that you can see what's going on, here.
The diagram at the bottom shows why you DON'T want to use an emitter with only a 1 degree spread. You want a nice wide spread to use the full curved surface of the mirror, and to minimize the amount of light blocked by the emitter itself.
- ParabolicMirrorDiagram.gif (10.56 KiB) Viewed 5618 times
- im1218073478.png (397.2 KiB) Viewed 5614 times
v_mulligan
Here's a version with a little bit of fog so that the beam is visible. Of course, the size of the emitter setup, intensity of the beam, and fog thickness would all have to be adjusted to get the desired effect -- but the proof of principle is here.
Again, the red rods have nothing to do with the laser. They're just for extra illumination.
- im1218077795.png (644.77 KiB) Viewed 5609 times
