For example you can run a whiteboard and paint and users connected have real time feedback !
http://gpu.sourceforge.net/
If the text seems to loose it's meaning sometimes that's because u can read the text before the user hit enter, so you can communicate without printing a line...(23:21:52:545 fr) CTZn> u there alex ?
(23:21:09:168 de) rendax> y ·
(23:23:49:152 de) rendax> gonna reconnect ·
(23:22:56:529 fr) CTZn> k
(23:24:28:498 fr) CTZn> well if it's working for terragen cud work 4 indigo
(23:24:21:152 de) rendax> it basically
(23:24:56:168 de) rendax> GPU will probably just start and stop the programs and send some data ·
(23:25:04:529 fr) CTZn> yes thats the point, to be a "portal" between users
(23:25:46:826 fr) CTZn> its just an architecture t
(23:26:03:482 fr) CTZn> do you see some possible issue with it ?
(23:25:25:152 de) rendax> m
(23:26:41:793 de) rendax> no ·
(23:26:40:529 fr) CTZn> igi are big
(23:26:51:199 de) rendax> maybe it would be enough it GPU would just
(23:28:26:123 fr) CTZn> Lol
(23:28:30:357 fr) CTZn> just what ?
(23:29:35:154 fr) CTZn> I am testing the chat translator
(23:30:38:824 de) rednax> so I'm back ·
(23:29:52:529 fr) CTZn> maybe it would be enough it GPU would just
(23:32:13:652 de) rednax> o
(23:32:34:981 de) rednax> does indigo currently send the data to the clients? ·
(23:32:48:654 fr) CTZn> yeah, packed
(23:32:47:324 de) rednax> so it would theoretically be enough if indigo would get the server adress over gpu ·
(23:32:55:857 fr) CTZn> zipped
(23:33:03:156 nl) Thexa4> hi ·
(23:33:04:529 fr) CTZn> hi, who's there ?
(23:33:17:281 nl) Thexa4> Max ·
(23:33:19:562 nl) Thexa4> are you new to GPU? ·
(23:33:31:184 de) rednax> y ·
(23:33:32:326 fr) CTZn> thexa: yes
(23:33:36:529 fr) CTZn> alex: do you think we can test now ?
(23:33:51:562 nl) Thexa4> do you know how you want to use gpu? ·
(23:34:08:529 fr) CTZn> like now
(23:33:48:481 de) rednax> could do that ·
(23:34:29:289 fr) CTZn> better said, no
(23:34:34:543 de) rednax> for rendering ·
(23:34:23:562 nl) Thexa4> I used it for rendering terragen movies for a while ·
(23:34:46:981 de) rednax> http://www.indigorenderer.com ·
(23:34:40:539 fr) CTZn> ok I follow your orders
(23:35:01:653 fr) CTZn> thexa: is this efficient ?
(23:34:55:562 nl) Thexa4> depends on how many computers are in the network ·
(23:35:15:887 de) rednax> what? ·
(23:35:27:562 nl) Thexa4> are you going to use indigo renderer with gpu? ·
(23:35:12:548 fr) CTZn> alex > I mean if you know how to launch a render using my cpus id be glad
(23:35:20:277 de) rednax> would like to do th
(23:36:02:407 fr) CTZn> Thexa > we are thinking about that
(23:36:16:402 de) rednax> there seems to be a scripting language ·
(23:35:59:562 nl) Thexa4> the
(23:36:15:329 fr) CTZn> we are just users
(23:36:25:796 nl) Thexa4> yes, I made it ·
(23:36:28:615 fr) CTZn> yes alex, good spot
(23:36:31:562 nl) Thexa4> but they are not realy usefull ·
(23:36:44:428 fr) CTZn> I read you thexma, wich was the last render engine used here ?
(23:37:03:562 nl) Thexa4> i
(23:37:07:593 nl) Thexa4> gpu can only render terragen at the moment ·
(23:37:18:671 nl) Thexa4> that's povray ·
(23:37:20:557 fr) CTZn> ah ok thx
(23:37:35:562 nl) Thexa4> is the indigo renderer open source / free? ·
(23:37:50:463 fr) CTZn> nope, it's closed source but free
(23:38:01:125 nl) Thexa4> could it be included with gpu? ·
(23:36:29:652 de) rednax> at least
(23:38:23:527 de) rednax> it already has network rendering ability ·
(23:38:11:260 fr) CTZn> thats the point, we don't know but possibly
(23:38:35:824 de) rednax> so for the moment it should be possible to let GPU call the renderer and let it connect to a specific IP adress maybe ·
(23:38:07:562 nl) Thexa4> yes, but you cannot use it with gpu ·
(23:38:46:234 nl) Thexa4> that way ·
(23:39:09:652 de) rednax> yeah its a bit of
(23:39:30:199 de) rednax> best
(23:39:11:562 nl) Thexa4> how do you render it? ·
(23:39:30:328 nl) Thexa4> with a dll or an application? ·
(23:39:41:652 de) rednax> its renderer from an external application ·
(23:38:56:557 fr) CTZn> why not ? with a small script yes, maybe !?
(23:40:00:557 fr) CTZn> ups sorry
(23:39:43:562 nl) Thexa4> what do you mean? ·
(23:40:15:562 nl) Thexa4> you can call me max ·
(23:40:14:573 fr) CTZn> is that possible thexma ? I meant that was getting to interesting points
(23:40:45:109 nl) Thexa4> the problem is interfacing the application with gpu ·
(23:40:52:500 nl) Thexa4> you need to give is some commands ·
(23:40:57:937 nl) Thexa4> like connect or render this file etc ·
(23:41:04:557 fr) CTZn> command lines ?
(23:40:13:652 de) rednax> currently there is no api for the renderer but there are commandlines with which you can start the renderer ·
(23:41:19:562 nl) Thexa4> yes ·
(23:42:23:562 nl) Thexa4> do
(23:42:39:843 nl) Thexa4> how do you store scenes? ·
(23:42:46:328 nl) Thexa4> to render I mean ·
(23:42:08:557 fr) CTZn> they can be sent packed by the software (rendere)
(23:42:21:652 de) rednax> afaik it does that automatically ·
(23:42:55:562 nl) Thexa4> can you set everything up through command line? ·
(23:43:12:557 fr) CTZn> yep
(23:44:16:156 nl) Thexa4> server and client? ·
(23:43:25:652 de) rednax> y ·
(23:44:56:448 fr) CTZn> thohoho, looks like almost done
(23:45:20:557 fr) CTZn> well i'm anticipating of course
(23:46:24:557 fr) CTZn> so according to what I understood, since indigo is sending all the data necessary only a little script is missing, is that correct max ?
(23:44:31:562 nl) Thexa4> yes ·
(23:47:04:375 nl) Thexa4> is the indigo manual for windows? ·
(23:47:08:995 fr) CTZn> oh woaw
(23:47:18:651 fr) CTZn> indigo works for win and linux (builds)
(23:47:33:312 nl) Thexa4> ah I see now ·
(23:47:43:562 nl) Thexa4> do you know how to make scripts for starting a server and clients? ·
(23:45:00:856 de) rednax> how come pe
(23:48:00:557 fr) CTZn> I don't but ppl on forum would
(23:48:15:562 nl) Thexa4> I'll try to look in the manual ·
(23:48:34:949 de) rednax> i just read you can use a batch file but you won't get the commandline right that wa ·
(23:48:58:606 de) rednax> w
(23:48:59:465 de) rednax> way ·
(23:48:47:562 nl) Thexa4> why not? ·
(23:49:19:562 nl) Thexa4> it seems pretty simple ·
(23:50:23:562 nl) Thexa4> does anyone have a server running? ·
(23:48:32:557 fr) CTZn> not me
(23:50:50:263 fr) CTZn> can I make our discussion public in a forum max ?
(23:50:55:562 nl) Thexa4> the program is open source, so the chat as well I think ·
(23:51:12:575 fr) CTZn>
set /P path=What scene to render:
set /P port=What port to listen to:
indigo %path% -n m -p %port%Users browsing this forum: No registered users and 23 guests
