(totally outdated !) Blender to Indigo photorealistic grass
Tutorials/guides/tips on how to use Indigo and the Indigo exporters
SurX
Post by SurX » Tue Aug 05, 2008 10:24 am
http://www.charlesrazack.com/3d/tuto1/tutograss-2-7.jpg
i have version 1.0.9 indigo .. i dont know which option configure .. please any try capture screenshot for version 1.0.9 .. please help
Jambert
Post by Jambert » Tue Aug 05, 2008 6:06 pm
Don't know the exporter you use, I work with "blendigo", but parameters are the same.
For exterior scene use bidirectional (for interior too), filter D65 is good... save IGI and use violet tone mapper for corrections of reinhard if doesn't look good :roll:
http://www.indigorenderer.com/joomla/in ... &Itemid=62
SurX
Post by SurX » Wed Aug 06, 2008 2:09 am
i dont know , where open xml with my metarial ( maked in bledner ) ..
Bogey Jammer
Post by Bogey Jammer » Wed Aug 06, 2008 7:01 am
The tutorial doesn't seem to be outdated o_O
But what does mean:
you'd rather use an instanced grass patch to get more accurate results.
I see nothing talking about "instanciation" in Blender
Indigo 1.1.11 32bit + Blendigo 1.1.7
My render supercomputer:
  • Acer aspire 5612Zwlmi
  • Intel T2060 dual core 1.6 GHz
  • 1GB RAM
  • vista home premium 32bit
Post by StompinTom » Wed Aug 06, 2008 7:15 am
alt-D creates an instance instead of a duplicate in Blender. basically it uses the same mesh, so if you change it, every instance gets changed. Blender 101.
Bogey Jammer
Post by Bogey Jammer » Wed Aug 06, 2008 8:04 am
Blender 101
Ok, but the tutorial shows exactly this technique, so I don't get the point about it. Maybe I'm thinking too much...
  • 1GB RAM
Post by StompinTom » Wed Aug 06, 2008 9:55 am
alt-D will prevent Blendigo (and Indigo) from exporting/loading/using the identical mesh multiple times (aka a waste of memory and time). if the mesh is identical, why should you load it twice? so what it does is make the renderer and exporter reference the original mesh any time it comes across an instance of it. bit like a placeholder for the real thing.
upon reading it again, it seems to me to be saying to use a patch of MODELED grass and instance that over your scene instead of using the alpha-mapped grass trick. so if you modeled/downloaded a small patch of grass, just use that and apply a green material to it. no more mucking around with alpha maps.
the downfall of this, of course, is the dramatically increased poly count which generally slows things down. however, if youre a purist like most of dem oh-but-thats-a-hack! people, modeling real grass is the way to go. of course, then it doesnt matter from what angle you look at it, itll still look like grass, so it really depends on your situation.
good luck, i hope this was somewhat helpful.
Post by pixie » Wed Aug 06, 2008 10:11 am
I just have added the material to IndigoDB
winnabago111
xml stuff.
Post by winnabago111 » Fri Aug 22, 2008 2:41 pm
So i copied the xml stuff as said and saved the file and it doesn't make a difference. After i edit the xml and save is there something i have to do in blender to activate it.
Tasaki
Where?
Post by Tasaki » Wed Feb 18, 2009 12:52 am
:oops:
hello, im new to the forum, im very interested in this especific topic... but i really cant find the XML file in my .blend folder... :roll:
am I doing something wrong or I skipd somthing hahaha... I just set UP the materials direct in the Blendigo's GUI, save the blend but theres no XML file for the materials... indigo 1.1.14
im really sorry been posting here... its an old topic but I really need this teq in a scene im making...
can some one help? :(
^^ thanks in advance
(sorry my bad english)
Post by Kram1032 » Wed Feb 18, 2009 6:07 am
(totally outdated!!!) ;)
You absolutely don't need that tutorial anymore (the export part at least), as Blendigo gained features which do those for you automatically! ;)
nathan.h
Post by nathan.h » Tue Mar 03, 2009 7:04 pm
i can only get the "Default" material to render when using the blend option in blendigo. changing it to any other texture results in this error message:
"IndigoDriverExcep: SceneLoaderExcep: Blend Material: no material with name 'grass_text' defined. (In element 'blend', around line 23, column 9)"
thus i can only render the grass as the default gray material.
my material.xml file:
<scenedata>
<material>
<name>Default</name>
<diffuse>
<albedo_spectrum>
<rgb>
<rgb>1 1 1</rgb>
<gamma>2.2</gamma>
</rgb>
</albedo_spectrum>
</diffuse>
</material>
<material>
<name>null</name>
<null_material/>
</material>
<material>
<name>grass_text</name>
<blend>
<a_name>null</a_name>
<b_name>grass_text</b_name>
<blend_factor>0.5</blend_factor>
<blend_map>
<path>..\..\users\nathan hamilton\desktop\3d work\lighthouse\textures\grass\grass_1_alpha.jpg</path>
<uv_set>uv</uv_set>
<exponent>1.000000</exponent>
<a>0</a>
<b>1</b>
<c>0</c>
</blend_map>
</blend>
</material>
<material>
<name>ground</name>
<phong>
<exponent>500</exponent>
<diffuse_albedo_spectrum>
<rgb>
<rgb>0.204785 0.33878 0.165088</rgb>
<gamma>2.2</gamma>
</rgb>
</diffuse_albedo_spectrum>
<ior>1.60838</ior>
</phong>
</material>
</scenedata>
blender v2.48
indigo x64 v1.0.9
blendigo v1.0.9
thanks.
Post by Kram1032 » Wed Mar 04, 2009 3:50 am
it would be of more use if you would also post screenshots of the materials inside blendigo........................
and maybe try to switch to the newest Versions of Indigo and Blendigo... (as the latest Indigo seems to be quite stable...)
nathan.h
Post by nathan.h » Wed Mar 04, 2009 4:27 am
i thought that the v1.0.9 that i was using was the most up to date build of both indigo and blendigo.
a shot of the working default material blended with a null:
and its render:
a shot of the nonworking grass_text material blended with a null:
and the same grass_text as a diffuse material:
and its render:
thanks for your help.
winnabago111
Re: (totally outdated !) Blender to Indigo photorealistic grass
Post by winnabago111 » Tue May 12, 2009 9:00 am
I downloaded the grass file with the xml and I still cant get the grass to work. It just looks like this every time.
http://www.charlesrazack.com/3d/tuto1/tutograss-2-8.png
Do I have to add in the XML somewhere. And is there a updated grass tutorial cause Im using 1.1.18 and blendigo 1.1.18. Thanks.
