balance your lights as a postprocess without rerendering
Yes, Photoshop is someway limited to 16bit for the work with EXR but still give a good result
A console program would be coool to blend EXR files:
c:\>EXRblend out.exr 0.2 in1.exr 0.5 in2.exr 0.3 in3.exr
is here a genius c++ coder that could have a look at this
@Nick,
Could indigo export separate EXR-files for each light-group (defined in XML)? That would be realy COOOOL
@Nick,
<meshlight>
<light_group>2</light_group>
</meshlight>
I like that light groups idea.
Keep in mind, that just off the top of my head, we're now dealing with n + 1 *framebuffers* where n is # of light groups, instead of just 1, so that will increase memory consumption. Efficiency losses from blending those n in memory to create the preview image will happen, too. Disk activity goes up.
Network rendering clogs your network more.
@Bz Win,
very nice renders
, you are right, you can do the same with the PNGs with 2 disadvantages :
- PNG is only 8bit, depending of gain you're apply you lose resolution
- As PNGs are gamma corrected, adding two PNGs isn't physicaly correct, i think
@zsouthboy,
yes memory usage and network traffic could be a problem
... user should have the option to tell indigo if it should render all at same time or sequentily
do you know how maxwell solve memory problem for there "light balance feature"?
@Big Fan: Yes blending exrs we will be able to do, we still need some simplifications on exporters (handling light-groups) and a "render queue" that automaticly renders the XMLs....
very nice renders
@zsouthboy,
This would be absulutely awesome....sorry but i think i missed the whoel discussion... something is wrong with the new forum i miss so many cuase it is not shown..zuegs wrote:Yes, Photoshop is someway limited to 16bit for the work with EXR but still give a good result![]()
@Nick,
Could indigo export separate EXR-files for each light-group (defined in XML)? That would be realy COOOOL![]()
<meshlight> <light_group>2</light_group> ... ... </meshlight>![]()
cheers
u3dreal
Would someone try my yellow software:
http://www.hostfiles.org/download.php?id=B645756B
(on your own risk
and without warranty)
Please unzip all DLLs and EXE to a directory. Then just try start Yellow.
If it comes up you can load EXR files with "Add" button. Scrolling view with left mouse button, zooming with right mouse button... and remember it's not finished and still buggy
(on your own risk
