How to model a blister package
Woodie
Post by Woodie » Thu Jul 31, 2008 4:20 pm
Well I have not used Wings for some time but just from curiosity I downloaded latest version and was able to create something in 2 min. Seriously.
1Create the cube, scale it so it looks like the base of the package (very thin, and a bit longer than wide).
2. select shorter edges and hit "C"
3. select the longer edges (including the newly created) and hit 4 (5 or more - depends how many you want in a package) and then "C"
4. select the top and bottom faces and use "Inset"
5. Select the top inside faces and Extrude by normal (Separated not Region)
6. Hit "L" (that will select the edges around the top) and use bevel
7. switch to Face selection and Hit "+" until you have selected all "bubbles"
8. Hit "L" again and use bevel again.
9. Select the bottom inside faces (created in Step 4) use inset again.
10. Raise the selected faces a little bit up.
11. Switch to object selection mode and use "S" until satisfied.
Good luck.
PS: I added couple more cross sections across the "bubbles" before using "S"
Post by neo0. » Thu Jul 31, 2008 5:40 pm
How do you make it so that hole in the bottom of the bubble (where you would open to take outwhatever is in the bubble) is the same shape as the bubble itself?
Cire
Post by Cire » Thu Jul 31, 2008 6:57 pm
You should probably do some basic modeling tutorials, instead of asking this kind of question in a forum focusing on rendering with a particular renderer.
Post by Borgleader » Thu Jul 31, 2008 10:04 pm
Cire wrote:You should probably do some basic modeling tutorials, instead of asking this kind of question in a forum focusing on rendering with a particular renderer.
+1
www.blenderartists.org or forums.cgsociety.org would be a better place to ask this kind of question.
Your best bet is blederartists.org though, it's got a user base of over 17000+ members so you're bond to get some help there. Following the Wikie Blender noo to pro would probably help also. There are plenty of basic tutorials out there, even if you don't complete them you'll surely learn from them anyway.
Post by neo0. » Fri Aug 01, 2008 1:13 pm
Woodie, could you post the wings file?
Woodie
Post by Woodie » Fri Aug 01, 2008 2:38 pm
There you go. Few versions attached (in one file)
pills.zip
(755.57 KiB) Downloaded 234 times
Post by neo0. » Sat Aug 02, 2008 7:12 am
Nice. One quick question though, how did you make the opening of the bubbles the same shape as the bubble itself? Whenever I do it, the opening is a different shape. The bubble looks like how it should, kind of a smoothed rectangular shpae but the bottom is always circular. :?
How does your mesh look prior to smoothing?
Mesh before smoothing
wingss huh.jpg (234.29 KiB) Viewed 3571 times
Post by StompinTom » Sat Aug 02, 2008 8:46 am
cuz you have to bevel the opening edges too, otherwise it will neatly subdivide to an oval.
Post by neo0. » Sat Aug 02, 2008 11:08 am
Thanks all for the help. See the WIP thread. :)
Post by neo0. » Sat Aug 02, 2008 6:18 pm
Right now, im looking for a way to close off the bottoms..
Post by Borgleader » Sun Aug 03, 2008 12:14 am
oh god... Does your 3d application not have form face option? you know like grab all four vertices and press a button and bam, hole is closed?
Post by CTZn » Sun Aug 03, 2008 3:58 am
Geometry would be non-manifold then, but who cares ?
neo0, delete all faces in the bottom, including the inner "bubbles"; then you can easily close the remaining rectangular hole.
Post by neo0. » Sun Aug 03, 2008 6:22 am
Borgleader wrote:oh god... Does your 3d application not have form face option? you know like grab all four vertices and press a button and bam, hole is closed?
The sad part is I don't know if it does.
Post by CTZn » Sun Aug 03, 2008 7:26 am
Ok, read its doc and do tuts :twisted:
No artistry possible if you can even not be a basical technician to the tool. One step after each other, young padawaan ;)
Post by Borgleader » Sun Aug 03, 2008 7:35 am
CTZn wrote:Ok, read its doc and do tuts :twisted:
+1000000000000000000000000
