bump map + normal_smoothing?
Post by suvakas » Thu Jun 05, 2008 11:02 pm
Hey,
I can't get the bump maping to work with normal smoothing.
Here are two images, 1st has a teapot with a bump map applied and 2nd without it.
Post by Zom-B » Thu Jun 05, 2008 11:47 pm
Seems to be related to this
Sould the connected to Sun Lightsource...
simply subdivide your mesh until your RAM bursts and you'll get nice shadows :-P
Post by OnoSendai » Thu Jun 05, 2008 11:50 pm
hmm, can you do a test with a very small meshlight in the same position as the sun, instead of the sun+sky?
supraserv
Post by supraserv » Fri Jun 06, 2008 12:12 am
I had the same problem months ago when I was creating my Egyptian scene. I noticed the same in some Maxwell renders elsewhere. I made a thousand tests but they didn't help.
Post by suvakas » Fri Jun 06, 2008 12:53 am
OnoSendai wrote:hmm, can you do a test with a very small meshlight in the same position as the sun, instead of the sun+sky?
Still same...
cookieofdoom
Post by cookieofdoom » Fri Jun 06, 2008 2:51 am
I'm pretty sure that kettle would never work right anyway. :P
Post by suvakas » Fri Jun 13, 2008 9:44 am
Hey Ono,
What do you think is the cause of this issue?
The problem is still there in 1.1.5 too...
v_mulligan
Post by v_mulligan » Wed Jul 30, 2008 5:08 pm
Hmm... I've seen something similar on Renderman-compliant REYES renderers. If you write a shader that calculates the bumped normal by perturbing true geometric normal rather than the smoothed normal, it looks a bit like that. I don't know why it only seems to be affecting direct light, though, and not reflected light. Of course, Indigo's a bit of a black box to me. Only OnoSendai can really say what's going on here.
v_mulligan
Post by v_mulligan » Wed Jul 30, 2008 5:13 pm
Hmm... Looking at it again, it looks like each of those polygons is either fully illuminated or fully in shadow, with regards to the emitter, but has proper intermediate levels of shading with regards to reflected light. Is there any chance that something that ought to be a float or a double is coming out as an int or a bool? Total stab in the dark, here.
Deus
Post by Deus » Wed Jul 30, 2008 9:53 pm
You are right mulligan it looks like the albedo direct lighting is completely broken :)
Ono maybe you should try general diffuse
color = cos( normal dot lightdir )
:lol: :lol: :lol:
v_mulligan
Post by v_mulligan » Thu Jul 31, 2008 6:49 am
Don't you just mean normal.lightdir? The dot product of two vectors is equal to the product of their lengths and the cosine of the angle between them.
Post by BbB » Thu Jul 31, 2008 8:10 am
That always happens with sun light and bump maps on low-geometry meshes. No way around it but to increase the polys. Pretty much all renderers are affected by the way. Not an Indigo singularity.
v_mulligan
Post by v_mulligan » Thu Jul 31, 2008 8:19 am
BbB wrote:That always happens with sun light and bump maps on low-geometry meshes. No way around it but to increase the polys. Pretty much all renderers are affected by the way. Not an Indigo singularity.
Um... no. REYES renderers certainly don't give that sort of image artefact unless you've done something wrong.
Raytracers might with very bright light since some edge polygons will be shadowed by other edge polygons. That still doesn't explain why the direct illumination seems to be uniform across the lit half of the surface, though.
Post by suvakas » Thu Jul 31, 2008 8:20 am
@BbB
Do you mean other unbiased renderers? Cause I haven't seen this kind of artifact with any other 3ds Max renderers i use.
zsouthboy
Post by zsouthboy » Thu Jul 31, 2008 9:04 am
Yeah not only that, I don't think this used to happen with Indigo, as well, but we never really had closure on it..
