[REQ] sun and hdri lighting
11 posts • Page 1 of 1
Kosmokrator
Post by Kosmokrator » Fri Nov 17, 2006 9:56 pm
the topic say it all....it wold be ideal to have lighting setup based on sunlight system and exr maps ....what u think?
mario
Post by mario » Fri Nov 17, 2006 10:01 pm
Not only with exr, but with jpg or another (tiff,etc)!!!!!!
SmartDen
Post by SmartDen » Fri Nov 17, 2006 10:49 pm
Is this really needed? If you use a exr lighing u have already a Sun-lightsource naturally. You can add some emitter light, but i don't sure if it works.
And lighting with a jpg is a humbug! Jpg have not enough light information to illuminate a scene.
8bstudio
Post by 8bstudio » Sat Nov 18, 2006 12:06 am
SmartDen wrote:Is this really needed? If you use a exr lighing u have already a Sun-lightsource naturally. You can add some emitter light, but i don't sure if it works.
Hi! I think that sun+exr is useful because with sun you have very sharp shadows like in sunny day, and with exr you have clouds and light changes around 360° (your object shall be illuminated differently around 360°)! I think!
Solution with emitter and exr... maybe good for sharp shadows!! I'll test!
8bstudio
Post by 8bstudio » Sat Nov 18, 2006 12:24 am
It seems work well exr+sun_emitter... mmmhh! Very good!
Now I must search dimension (x and y) of emitter to simulate real sun shadow. Someone knows some mathematical or geometrical relation between sun and ipothetical object?
SmartDen
Post by SmartDen » Sat Nov 18, 2006 1:21 am
8bstudio wrote:It seems work well exr+sun_emitter... mmmhh! Very good!
Now I must search dimension (x and y) of emitter to simulate real sun shadow. ...
I don't think it's trivial. Sun drops parallel shadows, also you have to simulate this. And you must find an exact position of strongest light source in exr image also.
8bstudio
Post by 8bstudio » Sat Nov 18, 2006 2:00 am
first test with .exr and "sun_emitter"
Too shining on "cu" material! Shadows looks good I think!
Here with sun
8bstudio
Post by 8bstudio » Tue Nov 21, 2006 8:55 pm
radiance wrote:hey 8bstudio,
can you post your xml ???
i can use this for an urgent project i'm starting tonight...
Yours,
radiance
Which one? First with exr and emitter or second who has only sun? Also textures?[/img]
8bstudio
Post by 8bstudio » Tue Nov 21, 2006 9:25 pm
8bstudio
Post by 8bstudio » Thu Nov 23, 2006 9:56 pm
Hi Radiance!
Here xml: http://www.8bstudio.com/bonus/chiosco4-exr-emit.zip
Try to change around "linear scale" or meshlight named "Plane"
I hope it's usefull for you!
Bye!
Post by CTZn » Fri Dec 08, 2006 9:54 am
Hi !
I think that one could use LightGen's plugin for HDRShop to define a directional light. Then the rotation has to be translated into a vector, that's a very few maths wich I don't know, sorry... or try to hack into some of the output files format generated, who knows ?
So it's about importance sampling, a simple app or even simpler: send a template of an xml scene with sun to the author:
If you want a new file format, be sure to send me a template for the file that the plugin should generate.
Just ask him to put 1 directional only, then compute the vector ! That'll be so easy I'm sure he will !
Would you ask Radiance ? I'm too new with Indigo to be positive on what features have to be implemented...
LightGen for HDRShop
