Indigo 1.1.6
CHF
Post by CHF » Tue Jul 22, 2008 9:15 pm
For this major step I want to say thanks for the great work, I really appreciate. Layering is an absolutly perfect new feature.
But I found, that exit portal no longer works for me. It just makes indigo crash. Same scene without it works nice. Anyway, still great new version.
Post by fused » Tue Jul 22, 2008 9:30 pm
i tihnk this is due to exit portals being materials now, too.
Deus
Post by Deus » Tue Jul 22, 2008 10:54 pm
Have the same firefly problem in 0.9 too.. Maybe its because I am using realistic water... or maybe my camera parameters are wrong
Post by pixie » Tue Jul 22, 2008 11:49 pm
Deus wrote:Have the same firefly problem in 0.9 too.. Maybe its because I am using realistic water... or maybe my camera parameters are wrong
You should know... after all you're Deus! ;)
Post by Pibuz » Wed Jul 23, 2008 1:00 am
Thank you so much Ono!
I'm SO curious about this revolutionary "multiemitter blending" system! is there any way i can export my scene from sketchy and render with this new 1.1.6 Indigo version?
Post by fused » Wed Jul 23, 2008 1:55 am
fused wrote:
Deus wrote:Also I found some strange firefly bug. (I havent run Indigo in a year so it might be my stupidity)
that looks exactly like when you try to mix 64 and 32 bit versions in network rendering (1.0.9).
at least thats the result i always get when trying this.
had it too. for me it happend with whats described above. are you doing the same?
Deus
Post by Deus » Wed Jul 23, 2008 11:05 am
No network rendering here. Just 4 cores :)
Big Fan
Post by Big Fan » Wed Jul 23, 2008 4:01 pm
ono can we have some details please :wink:
moving through it but what is tex index? is that like precedence?
Youn
Network render does not stop
Post by Youn » Thu Jul 24, 2008 3:36 am
I got network rendering working. But when I specify a haltspp the master stops but the slaves keep going.
I also get the MySocketExcep errors when stopping/quitting.
Lastly, the new tabs along the bottom of the indigo.exe UI are so large I can't see the real-time log info on some machines (none here have that high of resolution to stretch the window wide enough) and I'm finding the log file is not being written to even with explicit <logging>true</logging> in the ini file.
Lord of the Rings Junkie
Re: Indigo 1.1.6
Post by Lord of the Rings Junkie » Thu Jul 24, 2008 10:28 am
OnoSendai wrote: * added EXR as supported texture format.
Yay for 32 bit displacement maps! :D
Users browsing this forum: No registered users and 107 guests
