Indigo 1.1.6
- kwistenbiebel
Wow...Layer Blending! Great work Ono.
This is a major leap for Indigo in my opinion.
And thank you for the 64 bit version. That should take care of the larger RAM usage.
A little question at the side: Did anything change towards using displacement/subdivision? (As a Skindigo user I got unpredictable output with 1.1.5).
Ok, will try that.
Can the master confirm no support for nk mats? Will it return in the future?
@cinema: It's not that hard, simply specify two different emitting materials and assign them two different layers with the tag <layer></layer>, then when the igs gets loaded you should find this two layer available. Take care to the fact that to have layer blending u get rid off <meshlight>...i don't think they are supported for blending
so is violet being merged into indigo?
also, it appears updates are being applied every time the display updates a new frame. could this be changed to a separate thread that updates when it is ready instead? i set very long display times b/c applying the diffraction filter & updating the display drop cpu usage.
just my two cents.
just my two cents.
Yes i know, my spelling sucks
Wow nice stuff. Alot of the test scenes seem broken now though
<max_num_subdivisions>14</max_num_subdivisions>
<subdivide_pixel_threshold>5.0</subdivide_pixel_threshold>
<subdivision_smoothing>false</subdivision_smoothing>
<subdivide_curvature_threshold>-1</subdivide_curvature_threshold>
Is the pixel threshold in screen pixels?
Do the curvature_threshold = -1 mean random displace? What makes it random displace?
- Borgleader
- PureSpider
+1eman7613 wrote:so is violet being merged into indigo?
just my two cents.
and please stop the auto-updating if rendering is paused/stopped!
Re: pause and stop working
I dont think so here is a capture of the task manager for my single thread Pentium 2.66 pc -seems to be running on in a hurdles race...
um this is XPpro 32bit .net2.0 if that helps
The longer period is the start and then I selected pause - which are the bumps..
stop says that in the comments but keeps going in the same fashion
(BTW building a new O/C pc ATM + got a Dell 2707 LCD -old eyes you understand)
- screenie.JPG (90.36 KiB) Viewed 6538 times
- PureSpider
Here's a solution to everyone wanting to use layer blending without exporter support: set your materials that you want to be lights to "diffuse", then simply replace the materials with the similarly named ones.BbB wrote:I guess we'll have to wait for the exporters to do that...
Example: to make it easy, I copied the two materials from the /testscenes/layer_blending_test.igs, mat1 and mat2 (they're the same, just different layers)
Took a scene i already have setup, changed my lights to diffuse, and then replaced the diffuse material definitions with the layered light materials.
change:
<material>
<name>mat1</name>
<diffuse>
<albedo_spectrum>
<rgb>
<rgb>1 1 1</rgb>
<gamma>2.2</gamma>
</rgb></albedo_spectrum>
</diffuse>
</material>
<material>
<name>mat1</name>
<diffuse>
<layer>0</layer>
<albedo>
<constant>
<rgb>
<rgb>
0.8 0.8 0.8
</rgb>
<gamma>1</gamma>
</rgb>
</constant>
</albedo>
<base_emission>
<constant>
<rgb>
<rgb>
2000000000 2000000000 2000000000
</rgb>
<gamma>1</gamma>
</rgb>
</constant>
</base_emission>
</diffuse>
</material>
EDIT: So I do think that you're going to have to tweak the ranges for the lights, Ono - or perhaps allow a sunsky layer to tweak.
What do you think?
And I'm not sure dedicating such a large portion of the GUI to the individual controls of X,Y, and Z gain is useful (I know you love not hiding the advanced functions - which I can relate to
- tada.jpg (51.29 KiB) Viewed 6496 times
