Wow there's happened a lot since I last found me some time and some inspiration to do some 3d-stuff. I must say Ono's the man!
Well this was made for the 3dtotal smc which is running right now. It took a lot of time to get the precedence working since I hadn't used it before. I still think it's a bit weird that the middle of the "drops" aren't coloured, but I'm not sure if it's wrong.
Galileo thermometer
Galileo thermometer
- Galileo thermometer
- Thermometer.jpg (130.23 KiB) Viewed 6343 times
"And God said, Let there be light and pressed: "indigo The_World.xml""
Thanks for the comments from both of you.
@zsouthboy: I'm not sure what I can do with the normalsmoothing... It's on and my normals are pointing in the right direction. How do I fix it?
@ave: Yeah they look kind of flat, but they have the same material as the outer shell, so I have no idea how to make them more reflective, or actually how to make it show with the same material.
Tips and tricks are welcome!
