Phong material problem
10 posts • Page 1 of 1
Rafaello
Post by Rafaello » Sat Jul 19, 2008 8:32 am
Hi, I have a problem in 3ds max 9 with the Indigo phong material, it tells that there is an error with difusse color in maxigo script and the preview in the material window just show a shiny ball. I use Maxigo 1.09.6 and when I render the scene the material appears fine but I have to make trial and error rendering a plane until I tune the material to the right settings and then apply to the model.
-Rafaello.
Post by suvakas » Sat Jul 19, 2008 8:43 am
Hey,
Are you using a texture map or only color?
Also when do you get the error message? When you try to render a material preview?
Maybe you can make a screenshot of the error?
Rafaello
Post by Rafaello » Sat Jul 19, 2008 8:58 am
Hello suvakas, the error appears after I change the default scanline material and select the Indigo phong material and before I could touch any of the settings, next monday I'll post the screenshot.
Thanks.
Post by suvakas » Sat Jul 19, 2008 9:11 am
Are the other materials Ok or do they give the same error message?
Rafaello
Post by Rafaello » Sat Jul 19, 2008 9:22 am
By the way... Great job, congratulations.
I'll check for other errors in the weekend and tell you about it, I also tried the 1.1.5 version and when I import a material or create a new one, same result.
Rafaello
Post by Rafaello » Tue Jul 22, 2008 5:06 am
Hello again, here are the images of the exceptions I found in phong and glass materials, and when I select a blend material the preview window doesn't work.
I hope they can be useful.
This is the exception with glass
This is the exception with phong
Phong 3.png (29.58 KiB) Viewed 5247 times
Select a phong material
Phong 2.png (14.29 KiB) Viewed 5246 times
Select a new material
Phong 1.png (18.31 KiB) Viewed 5247 times
Post by suvakas » Tue Jul 22, 2008 5:32 am
Wow, something is really messed up there.
I have no idea of what is going on or what's causing it :?
I would have to debug the script on your workstation, then maybe I could find something, but for now.. sry, I'm affraid I can't help.
Did you install the maxigo correctly? (probably a stupid question)
Do you have any plugins installed?
Is the "Standard" material type still there? Maxigo is based on "Standard" material type.
I'm out of ideas...
Rafaello
Post by Rafaello » Tue Jul 22, 2008 5:57 am
Hi suvakas, I have installed fryrender and maxwellrender plugins, I don't know if there is a problem with one or both of them, as I said before the preview for phong and glass materials works fine but the blend material preview doesn't, but I don't think this is a big problem because the render works fine, I will clean up my PC and install all over again and then I will tell you what happened.
thank you.
Rafaello
Post by Rafaello » Wed Jul 30, 2008 7:01 am
Hello suvakas, I'm using Indigo 1.1.7 with maxigo 1.1.5 and those script errors were gone. I guess the problem was in Indigo, because with this beta release everything in maxigo works fine.
Post by suvakas » Wed Jul 30, 2008 7:53 am
Great to hear, that you got it to work. 8)
