palawat
by palawat » Mon Jul 14, 2008 10:50 pm
Thank you, SmartDen.
Testing it now with a 100 frames, simple cloth scene (Halt time set to 600).
Will report back tomorrow.
Cheers,
SmartDen
by SmartDen » Tue Jul 15, 2008 1:14 am
palawat wrote:Thank you, SmartDen.
nice. ^_^ waiting fo your report ^_~
Check normals, dude!
palawat
by palawat » Tue Jul 15, 2008 5:35 pm
<edited2>
Here is a 4sec., 400x300, 25fps test. The 7.z file is 17 MB.
http://www.tonedev.com/indigotest/clothTest.7z
<edited>
SmartDen, the cloth sim.
does work. I found out that in order to make it work, the Subsurf modifier need to be "Apply" first.
BTW. It'd be great to generate sequential file's name as filename-001, filename-002,... than filename-1, filename-2,...for consistency of importing all the arranged-by-name .png into video editor software.
Cheers,
neepneep
by neepneep » Thu Jul 17, 2008 4:22 am
Woodie wrote:I'm getting problems when using material preview.
mmyjona wrote:can anyone fix the proview problem?
Has there been a solution to this yet?
How is everyone else getting around this problem??????
by Borgleader » Thu Jul 17, 2008 4:46 am
Yes it has...right under Woodies post...unless you,re having a different problem in which case a little more detail-ism would be appreciated.
neepneep
by neepneep » Thu Jul 17, 2008 8:45 pm
Thanks Borgster, but you only mentioned that you were also experiencing the problem in that post and there was no solution to it (unless you somehow wrote it in supersneakysubscript text.)
To clarify, it's the "UV set with index 0 was exposed, but the UV set data was not provided" error.
by Borgleader » Thu Jul 17, 2008 10:03 pm
I'm not sure but if you rename all of you uv set names to custom stuff i think it helps.
For example I name them to like :
uvC (for Cloak material)
uvF (for Floor material)
Maybe if you try that it'll work. Unless you had custom stuff on already.
SmartDen
by SmartDen » Fri Jul 18, 2008 1:44 am
i've almost fixed it.
Woodie
by Woodie » Fri Jul 18, 2008 1:54 am
Borgleader wrote:Yes it has...right under Woodies post...unless you,re having a different problem in which case a little more detail-ism would be appreciated.
Solution you mention is in regard of only MatDB preview scene, right?
SmartDen
by SmartDen » Fri Jul 18, 2008 10:29 pm
Updates are out! minor fixed script and previes
Woodie
by Woodie » Fri Jul 18, 2008 11:54 pm
Quick question Smart. When you post updates you update all files? exe, zip and py? I'm asking because now we have previews.zip and theoretically those should be included in zipped and exe version as well. Correct?
by Borgleader » Sat Jul 19, 2008 12:01 am
I was actually wondering about that too...
SmartDen
by SmartDen » Sat Jul 19, 2008 12:03 am
i alway update all files. but maybe somebody wants to update only previews...
i can delete it if it's too much
by Borgleader » Sat Jul 19, 2008 12:04 am
Nah don't delete it. It's just that by habit I always download the installer, because it's quicker.
