Arrival
12 posts • Page 1 of 1
Johan
Arrival
Post by Johan » Thu Jul 10, 2008 7:39 am
3dsMax and Maxigo.
The cherub was borrowed from the Doom 3 "Id software" imported into 3dsmax using an md5 import script.
I needed a character like that, so I just added a few polys. All posters are just some renderings I made earlier. Some adjustments in Violet and later ps.
Cheers
Johan Sae-Thao
Kosmokrator
Post by Kosmokrator » Thu Jul 10, 2008 7:50 am
niiice!!!
Post by Borgleader » Thu Jul 10, 2008 9:00 am
Thats very nice...yet very creepy.
Post by CTZn » Thu Jul 10, 2008 1:21 pm
Hello Johan ! I think your image has some good potential, but it has to much contrast and so is hardly readable... maybe you are on apple computer (stronger gamma) ? For instance I can't say what's this object on the foreground (if any)...
At this point I would experiment more with tonemapping; wich did you use + settings please ?
Johan
Post by Johan » Thu Jul 10, 2008 6:58 pm
Thanks for the comments, I wanted it to be high contrast, but as I knew whats what and where it is. I never thought other people would have a problem to understand my layout. This is my fault, bad POV.
I think I could try another camera insted of lighting the interior up even more. It should be dark, with a strong backlight "Sun".
I will see if I can fix the scene, it was more of a Indigo playaround anyway :)
Bye
Johan Sae-Thao
Post by BbB » Thu Jul 10, 2008 8:42 pm
Creepy in a very nice way.
BigSean
Post by BigSean » Thu Jul 10, 2008 8:57 pm
Wow, nice and creepy. Good job!
Post by CTZn » Thu Jul 10, 2008 11:51 pm
Oki Johan, I understand your point, and the second image helped me a lot by the way. Now it makes sense to me, and yes, I guess creepy is the right term to use :)
Post by Borgleader » Fri Jul 11, 2008 12:03 am
I don't know much about lighting but it looks to me like you probably could fix this by adding a faint light in back of the camera. Not strong enough so that you know it's there, yet bright enough so that we can see the scene better. I haven't touched 3DS in a while so I forget which type of light would be appropriate for this task.
Just a thought :)
zsouthboy
Post by zsouthboy » Fri Jul 11, 2008 1:43 am
I disagree with the crits - it's an intentionally artsy shot that I honestly couldn't tell (except for the rocks texture) wasn't simply photoshopped together.
It's contrasty in the same way horror movies or dramas can be - you want, really want to see whats in the dark portions of your view, but - there's no light. Tension.
m.f.t.
Post by m.f.t. » Fri Jul 11, 2008 2:02 am
simple yet very effective... i really like it.
i think you can try the scene with a faint fill light like Borgleader said, and compare yourself, which one expresses better...
if i were you, i would try with a green light
:wink:
Johan
Post by Johan » Fri Jul 11, 2008 5:18 am
//if i were you, i would try with a green light//
I could try a fill light, if it doesnt work, I agree. I dont have to use it. Green color is a color I would belive in to. There is already orange lights and some blue color from the environment that find it´s way. When I color adjusted the Image in ps, green was a color I liked, but didnt use. I only applied some blur here and there using masks, and a final color/highlight adjustment "Pal and ntsc safe". I also tend to look on the render saturated. Detail should be visible saturated to......
I will see what Iam gonna do. Been doing Object oriented renderings and some architectural interior viz lately. But been working as an game level designer long time ago. Could be fun mixing everything together, medium poly and a realistic render, like Indigo.
I have some differant ideas.....
Thanks for the feed back :)
Users browsing this forum: No registered users and 220 guests
