Maxigo 1.15.7-Test1a [update-09.07.08]
Hey,
Here is the test version i've been talking about.
It is not a full package, but contains only files that have been updated. Just copy them over to previous Maxigo installation.
Since this is a test version, then you can expect a lot of bugs and missing/non-working stuff. My only goal with this version is to get some feedback about the re-written Import Material. I dumped my old xml parser code and started to use the dotNet parser. So guys - please test and report back if the material importing is working or not. I'm specially interested if it works outside my box at all.
NB! dotNet is not working in Max versions prior to 9.
Change log:
added - Maxigo displacement modifier (not working with procedurals)
added - Indigo Sphere primitive under Maxigo geometry category (not working when exporting to xml format)
added - Network rendering modes
changed - ImportMat rewriten to use dotNet parser
changed - bump maps have decimal values now
fixed - various fixes on bump and exponential export
So guys - please TEST the ImportMat and REPORT back !!
Take care!
Suvakas
[edit]
A small update -Maxigo 1.15.7-Test1a.zip
There should be a better displacement export now. Those broken edges should be gone + it is now scale dependant. Please test!
Change log:
Take care!
Suvakas
[edit]
- Maxigo_1.15.7-Test1a.zip
- update on 09.07.08 - better displacement export
- (388.48 KiB) Downloaded 857 times
- Maxigo_1.15.7-Test1.zip
- (388.4 KiB) Downloaded 577 times
Great stuff, Suvakas!
It's working for me (using Max 2008.) I imported a couple of materials from the Materials Database and they all imported fine - no errors or anything.
I noticed, however, that a material that has a Displacement Map doesn't displace in Indigo, but as this is still a test version I'm sure that's one of the things you're still working on.
Thanks again for all your effort!
- Doug Armand
- Kosmokrator
- Doug Armand
How do I install it?
hehe showing my limited knowledge but I have never seen a .MSE file before. Where do they go?
Doug
Doug Armand
Doug Armand
- Kosmokrator
ok suv i have the first report....
all works fine...until now.....
about import material i add an displase mat from the gallery works fine....
also i have little error msg when i import this material "Diamond Fancy Yellow "
here is the msg....and i thin dont import and renders correctrly after i press ok..
- err.jpg (41.7 KiB) Viewed 26361 times
