ronald8
by ronald8 » Thu Jul 03, 2008 2:10 am
Hello -
I searched the forum and did some google but cant find a solution
My setup:
blender 2.46 with ubuntu 8.04 and indigo 1.0.9_3 under wine 1.xx
blendigo is v1.09
Blendigo seems to work but indigo couldnt load the texture(s) for the material preview scene. Here is the log:
Scene file path: 'previews/IMPmatdb.xml'
Using working directory path 'previews'.
Loading Scene 'previews/IMPmatdb.xml'...
Using Reinhard tone mapping with pre_scale=7.000000, post_scale=1.150000, burn=5.500000
Processing included XML file 'previews\previewmats.xml...
(around line 16) WARNING: Overriding material definition for material 'null'.
Calculating energy loss compensation curve for exponent 500.000000
trying to load texture from 'previews\..\textures\preview_logo.jpg'...
couldn't open 'previews\..\textures\preview_logo.jpg' for reading.
Thanks in advance for your help!
- Error Message
- Bildschirmfoto-Indigo - Fatal Error.png (2.77 KiB) Viewed 9283 times
by Borgleader » Thu Jul 03, 2008 2:21 am
I had the same problem. couldnt fix it however
SmartDen
by SmartDen » Thu Jul 03, 2008 3:04 am
attach the scene. i need the material you used there.
Check normals, dude!
ronald8
by ronald8 » Thu Jul 03, 2008 5:31 am
There is no scene yet
I just followed the tutorial posted here in the forum
http://www.indigorenderer.com/joomla/fo ... php?t=2921
It says that i can do a Material preview ...
Now press the Preview Button, and in a short time a new window will open rendering the default sphere scene from the previews downloaded together with the blendigo exporter
ronald8
by ronald8 » Thu Jul 03, 2008 6:08 am
Ha!
The default selection in my blendigo script was
matDB for material-previews, not
sphere like in the tutorial. It works now to render the sphere preview!
I dont know what "matDB" stands for and what should indigo render when this is selected - but it doesnt work
I guess I had to check the matDB XML ...
- that was wrong
- blendigo.png (127.07 KiB) Viewed 9204 times
ronald8
by ronald8 » Thu Jul 03, 2008 6:24 am
Eeek!
Sorted it out!
in the matDB XML in previews (default for material preview in blendigo 1.09) is this:
<path>..\textures\preview_sss-bar.jpg</path>
i changed it to this:
<path>/textures/preview_sss-bar.jpg</path>
now it works like a charm
@SmartDen: Maybe you can fix this, or add a comment to the readme for all those linux users ... ?
SmartDen
by SmartDen » Thu Jul 03, 2008 9:49 am
thanks ronald8! i'll fix asap.
