- aleksandera
Bertrand, I know you are. That makes now three of us.
Wery nice CTZn! I like the first one too.
Well you can convince me by render
properly this file here:
http://www.indigorenderer.com/joomla/fo ... c&start=45
If I'm honest, the biggest problem for me in Blendigo 1.1.5 is
the new UV stuff.
Can anyone post a decent tutorial abaut this?
the new UV stuff.
Thanks a lot both ! I havent showed these much before, and they have a few years now, the "camel man" is the most recent (~2 years). You'll understand me better when I say i'm a lazy guy
And anyway I'm not experienced enough with ZB itself to call myself a ZB user, "Camel Head" is just a successfull sculpt amongst many tries... For instance I know ZB has 3 ways to export UVs on meshes but I couldn't say wich suits Indigo better...
Aleksandera, I swear your scene would be rendering by now here, if it wasn't a blend
Thought in the post following yours, zsouthboy is pointing the same solution than I did; definitly you should give that <c> a try !
To explain things better the uv shells are pushed in the direction of the normal of the mesh. <c> tells indigo to slide the patches along this normal; at a certain value they will be in contact.zsouthboy wrote:Hi Smartden,
Can you add the <c> parameter for displacement maps?
We can then set it to -<b>, so that the entire mesh doesn't appear to change positions.
- aleksandera
lol wait
That's what I got from Maya internal with displacement as color. For this I left alpha gain (<b>) to default 1 and set alpha offset (<c>) to -0.650. This is not guaranteed conform to the original (in ZB) since I'm guessing the values here.
Now I'm going to work for an export toward Indigo !
Btw on the different techniques ZB has for UVs... I would definitly not choose this one, it has too much uv shells ! I may investigate this at some point.
Attachment was deleted because of unrelated uglyness.
Aleksandera: I can imagine your face when you first saw the above pic
sorry for that, as I told that was guesswork
Ono, apologies, I've been a bit of an @$$hole not to tryearlier.[/u]
<merge_vertices_with_same_pos_and_normal>true</merge_vertices_with_same_pos_and_normal>- Attachments
- aleksandera_disp_test.pigs.zip
- The packed scene. OMG the server could test for the file type [u]before[/u] uploading
- (1.65 MiB) Downloaded 176 times
- obviously he's not Frankenstein...
- im1214572706.png (441.03 KiB) Viewed 4083 times
That's how maya internal displacement manages this too... Indeed it is not enough to set c=b/2, you also need to know the right value for b and I believe zb provides this at some point. That's because I don't know this value that you can see some glitches i believe, for me it's working 100%. (edit: erm that's not correct finally)
edit added packed scene above
edit 2: Actually I'm investigating more on this. To tell the truth I would love to investigate a proper doc, explaining what <c> should be set to, because it is necessary for compatibility with most 3d apps featuring displacement, and those who don't need it can leave it alone anyway.
Ono, we should take you away from your computer a bit and give you a pen and a block of paper sheets. Until we get a doc on new Indigo features. Struggling is not for anyone, yes that's me saying this !
Sorry for double popping again but since there is a new related thread I wanted you to know...
Isn't the b value relative to the object's scale in your exporting 3D app? In this case, unless you can export straight from ZBrush to Indigo, setting b at the right value can only be a matter of trial and error. AND, it will be different for every new scene/object/sculpt...
What we would need then would be a standard workflow for ZBrush-to-(your 3D app of choice)-to-Indigo that also includes scale.
I've no idea what I'm talking about so please correct if I'm wrong...
- aleksandera
Another one I posted here before. It kinda looks
ok, not mentioning the seam region.
http://www.indigorenderer.com/joomla/fo ... &start=105
Edit: Ups, Im posting it on the other thread also..
By the way I didn't answer to you BbB; yes b is expressed in Indigo units, it's the same for bump unless the later is kinda fake would say Ono. I guess ZB has an internal unit system too, or it wouldn't provide alpha depth; it is directly usable in Maya and Maya uses cm, so divide the value /100 from ZB to Indigo. My guess.
- Borgleader
