Crash after 15-50 mins.
Post by OnoSendai » Sun Jun 22, 2008 5:17 am
If you have a scene that is causing Indigo crashes:
Try and simplify it as much as possible, while still making sure that it crashes.
Then email the scene (.pigs format pls) to me and i'll have a look.
Bogey Jammer
Post by Bogey Jammer » Sun Jun 22, 2008 6:43 am
OK I'll do that 8)
Bogey Jammer
Post by Bogey Jammer » Wed Jun 25, 2008 4:36 am
argh, I made the simplified scene with all the emitting meshes and it didn't crashed..
Since I don't have time to render the same scene again for ten and ten hours I temporary conclude that my scenes must be quite balanced for safe rendering on my hardware...
Indigo 1.1.11 32bit + Blendigo 1.1.7
My render supercomputer:
  • Acer aspire 5612Zwlmi
  • Intel T2060 dual core 1.6 GHz
  • 1GB RAM
  • vista home premium 32bit
Post by OnoSendai » Wed Jun 25, 2008 8:17 am
Sorry, but 'balanced' does't mean much as a technical term. You'll have to do a better bug report than that :) I need specifics :)
Bogey Jammer
Post by Bogey Jammer » Thu Jun 26, 2008 3:25 am
What I meant is when I render the emitters+complex scene, it crashes. But not the complex scene without the emitters or the emitters+simplified scene. So the meaning of balanced is that I must simplify both the scene and emitters in some way to succeed. Because after theses test I could not find the problem origin and it is probable that it comes from my computer.
I apologize for not telling more useful since I can't do very much to step forward in this problem and my computer wants to sleep :?
  • 1GB RAM
zsouthboy
Post by zsouthboy » Thu Jun 26, 2008 3:28 am
I didn't read back through the thread, have you tried letting someone else render the scene that crashes for you to see if it crashes for them?
Post by CTZn » Thu Jun 26, 2008 6:10 am
Got a heat monitor ? 2cts
Post by Zom-B » Wed Jul 02, 2008 3:05 am
Sayris just got such an Problem with a scene too.
its crashing from 1 to 15 minutes after render started, on my system too.
So I'll try to reduce this 0.5million Poly bitch... until then I attached the 3 error log Files my Vista 64bit produced on Crash zipped.
error_output.zip
(157.3 KiB) Downloaded 167 times
Post by suvakas » Wed Jul 02, 2008 3:28 am
I had a strange crashing scene too in a few days ago. Nothing too complex.
Switching to BIH instead of a KD-tree stoped the crashes.
leau2001
Post by leau2001 » Sun Jul 06, 2008 2:58 am
Crash Here with blendIndigo 1.0.9 and indigo 1.0.9 On Ubuntu 7.10 after more 1hour... problem with wine
http://friendpaste.com/JAxkYm2b
http://friendpaste.com/WVQY7E5p
Athlon xp 2600 1go ram
thx
Pinko5
Post by Pinko5 » Mon Jul 21, 2008 5:32 am
I had a strange crashing in my new scene...it works fine about 4 hours then Indigo send an error but if i dont click on the button for close the error window the render continue his work.... :shock: :shock: :shock: :shock: :shock: :shock:
Any ideas??? I could like to try with Suvakas solution but in Blendigo where is this choise??? "BIH" "KD-TREE"???
Luca. :(
danbush
Post by danbush » Thu Jul 24, 2008 1:41 am
I'm just starting with Indigo and sketchup and do not know ANYTHING about the technical side of renderers. I've had similar crashes with VERY simple scenes - in my case, Indigo crashes when I render using MLT but not with BiMLT.
I have not yet found a good explanation of what the differences are between all of the options - any suggestions for me?
