Post by Borgleader » Tue Jun 24, 2008 4:05 am
Hehe sick test.
zsouthboy
Post by zsouthboy » Wed Jun 25, 2008 1:18 am
Here's a sun-copper-reflected caustics test with the same scene.
Post by Borgleader » Wed Jun 25, 2008 1:32 am
even nicer than the other one. I like the orangy touch, is the water made with plane that you derformed to make wave or did you use the fluid sim? (i suspect the first option, but not sure)
Post by Borgleader » Wed Jun 25, 2008 1:33 am
zsouthboy
Post by zsouthboy » Wed Jun 25, 2008 2:20 am
Waves are clouds texture used as displacement modifier on a plane subsurfed a few times in blender.
Post by Borgleader » Wed Jun 25, 2008 2:31 am
I see. Simple yet effective :)
Post by OnoSendai » Wed Jun 25, 2008 8:21 am
Reflected sunlight caustics.. You're trying to kill my poor ray tracer aren't you!
zsouthboy
Post by zsouthboy » Wed Jun 25, 2008 8:26 am
OnoSendai wrote:Reflected sunlight caustics.. You're trying to kill my poor ray tracer aren't you!
Don't act so high and mighty, I'm trying to kill other ray tracers with it too. :D :D
I'm amazed at how easily the caustics under the water showed up though - great strides have been made since, I don't know .6 (I wonder how hard it would be to get this scene into it and test, actually).
Indigo has changed so much in so short of time.
Post by OnoSendai » Wed Jun 25, 2008 8:27 am
heh.
I presume you're using exit portals?
zsouthboy
Post by zsouthboy » Wed Jun 25, 2008 9:03 am
Nope! Completely forgot to add a portal, Ono!
I feel stupid.
Post by BbB » Wed Jun 25, 2008 10:30 am
I think this is one of the areas where Indigo has a very clear edge over the (commercial) competition. You'd never get caustics like that with sunlight in any of the other two apps...
Post by CTZn » Wed Jun 25, 2008 6:23 pm
These indirect caustics are insane ! gw.
Post by PureSpider » Thu Jun 26, 2008 12:58 am
zsouthboy
can you share that scene, especialy the water?
How did you do the riples?
zsouthboy
Post by zsouthboy » Thu Jun 26, 2008 2:01 am
I left the .blend on my work computer, but here's how to copy it:
make big box (thick walled)
cut hole in bottom
cut hole in side
toss camera in box
make pool sidewalls
toss a plane where you want pool water
add subsurf modfier (simple) to that plane, level 6
add displace modifier to that plane with clouds texture as input
uv map some cement texture onto big box
add a sun to scene and point it through the side hole in big box
toss a uvsphere next to pool
render and enjoy.
Sounds like a recipe for cookies.
And cookies are only slightly less awesome than Indigo.
Post by PureSpider » Thu Jun 26, 2008 2:09 am
Hehe thanks! :)
