€dit: Hm... do we have to pay the 10 bucks?
The RANCH renderfarm now supports Indigo!
- PureSpider
- RenderFred
- PureSpider
- RenderFred
Explainede in the manual on side 6PureSpider wrote:Okay fine
Another question... What filetype to upload at the RANCH page?
Cause my scenes always use external models...
pack via Indigo, and rename the package to vui for upload!
Just for Info, Beta tester got a 15min render limit and max 1024x1024 resolution, but on such a Farm this should be enough to get some nice results^^
I just started a SSS test that would render on my system for weeks!
I just found a bug in Ono's Scene Packaging that prevents using this service with camera tonemapping:
Ono, while packing the scene you still left the path for the <response_function_path>
untouched instead of packing the file into the archive!
So guys, if you BetaTest use Reinhard or Linear
- PureSpider
Job Project name Current job(s) status Elapsed time Status
001 : star.igs RENDERING (SPP~ 13361) 00h 06mn 00s running13k SPP after 6 minutes?
- PureSpider
Ah I got a bug...
Watch the render time
001 : star.igs RENDERING (SPP~ 42826) 00h 17mn 07s running
(1024 x 585 - Render Phase Limit: 15 minutes, maxi Samples Per Pixel: 999999)
- PureSpider
Hi ZomB,ZomB wrote:I just found a bug in Ono's Scene Packaging that prevents using this service with camera tonemapping:
like nk data, custom camera response functions aren't really meant to be used currently. Is it one of the ones from the original archive?
PureSpider did ya defined the halt conditions in your igs file as -1 ???!
Because maybe the internal igs parameters are stronger then some command line definition -.-
If this is the point, this Baby will render for ever
EDIT
Yes Ono ist the original one... exported via cindigo for absolute path!
EDIT
- RenderFred
Yes it seems that it's what happened, the scene was not interpreted correctly by the parser, so I had to stop it. I'll look into it.ZomB wrote:PureSpider did ya defined the halt conditions in your igs file as -1 ???!
EDIT
