by neo0. » Mon Jun 09, 2008 11:23 am
The glass looks a little too prism like.
I used the glass preset (specular material.) I wasn't sure what to put for the scattering coefficient or the cauchy b.
kwistenbiebel
by kwistenbiebel » Mon Jun 09, 2008 11:38 am
Good start, but I don't see the connection between the medical and the wiimote....
kwistenbiebel on Mon Jun 09, 2008 1:15 pm, edited 1 time in total.
by neo0. » Mon Jun 09, 2008 12:12 pm
For some people, Wii is like a drug craze.
What should I put for the cauchy b and the coefficient?
kwistenbiebel
by kwistenbiebel » Mon Jun 09, 2008 1:17 pm
Well, I think people won't automatically make the connection between the syringes and drugs in this image, unless something more of a clue is given.
Can't help you with cauchy b and coefficient, sorry.
The trick will be getting the 'precedence' for both media (glass and fluid) correctly.
Maybe the material experts on this forum can be of assistance...
by neo0. » Mon Jun 09, 2008 2:22 pm
Yep, I set the precedence for the glass to be higher than the fluid.
mr_jo
by mr_jo » Mon Jun 09, 2008 8:51 pm
neo0. wrote:Yep, I set the precedence for the glass to be higher than the fluid.
Hi neo, maybe the
fluid should have
precedence higher than the glass
by PureSpider » Mon Jun 09, 2008 11:20 pm
No, the glass precedence higher than the fluids is just fine, just use a b_coeff of 0 for the glass as the coefficient marks the dispersion (prism effect) of the glass
mr_jo
by mr_jo » Mon Jun 09, 2008 11:30 pm
PureSpider wrote:No, the glass precedence higher than the fluids is just fine
sorry guys, I've problems with my bad english
zsouthboy wrote:Precedence allows you to model volumes without having to hack them up to put them inside one another.
For example, you can enclose your scene with a SSS air volume for a fog effect, and give it a precedence of 1.
If you have another volume (say a cup of water) in your scene inside the air, you just choose a higher precedence for it to "displace" the lower precedence volume, so 2 or higher.
and put a piece of SSS plastic in that water -> precedence of 3 or higher.
The SSS plastic will automatically displace the fog and the water, and the water will automatically displace the fog.
http://www.indigorenderer.com/joomla/fo ... php?t=4272
by Kram1032 » Tue Jun 10, 2008 2:41 am
mr_jo, the glass still has to have higher precedence than the fluid
(except neo0. modelled the syringes as if they are solid glass cylinders and added a fludicylinder, to get the hole...)
How ever it might be, precedence looks right, here.
I only never saw a glass syringe - they usually are made of plastic with close to no chromatic dispersion....
mr_jo
by mr_jo » Tue Jun 10, 2008 3:05 am
Kram1032 wrote:mr_jo, the glass still has to have higher precedence than the fluid
thanks Kram I'm sorry for my misunderstood
P.S. I have a doubt
example: if I have a glass with prec=1 and a fluid whit prec=2 this for me means that the fluid has higher precedence (2 major than 1), is correct? or the minor number (1) means higher precedence?
Sorry again
mr_jo
by mr_jo » Tue Jun 10, 2008 3:09 am
zsouthboy
by zsouthboy » Tue Jun 10, 2008 3:10 am
The precedence number should be interpreted literally.
Precedence of 2 is higher than 1, therefore material with precedence 2 will "displace" material with precedence 1.
mr_jo
by mr_jo » Tue Jun 10, 2008 3:26 am
zsouthboy wrote:The precedence number should be interpreted literally.
ok thank you zsouthboy;
so I'm a little confused with precedence (or the fault is of my bad english
); did you see my render of "pinocchio"? well if the precedence of my water is 10 and I decide to put a bottle of glass underwater, wich precedence should I assign to the glass?
zsouthboy
by zsouthboy » Tue Jun 10, 2008 3:39 am
Glass needs to be 11 in that case.
Make sure you model the thickness (but I think you understand that already)
EDIT: And your english is fine - I think you're having a tougher time understanding us than we are of you.
mr_jo
by mr_jo » Tue Jun 10, 2008 3:50 am
zsouthboy wrote:Glass needs to be 11 in that case.
ok, I'm in, thanks zsouthboy
zsouthboy wrote:Make sure you model the thickness (but I think you understand that already)
yes, yes is the first thing I've learned
zsouthboy wrote:EDIT: And your english is fine - I think you're having a tougher time understanding us than we are of you.
Users browsing this forum: No registered users and 243 guests
