SkIndigo 1.0.9 Official
Thanks!!
This is probably me missing something, but heres what happened :
1) Needed an NK metal, so I guess what the filename is.
2) When I clicked export skindigo gave me an error than indigo itself gave me a second error message
3) I clicked on the material to revise the NK data, but skindigo had forgotten what material settings I had assigned to the su material.
4) However, it still complained about the bad nk value, and it wouldnt let me render.
This is probably the source of the error.neo0. wrote: 1) Needed an NK metal, so I guess what the filename is.
1) select the nkdata from the list of presets.
2) click the button beside the nkdata path to browse for the nkdata file
If these two choices don't work, there could be a problem.
Can't get started!
Hello all! I want to start learning indigo render for sketchup pro for architecture school in the fall, but can't get it to load. I followed the instructions that were in the forum on how to load it, but when I open sketchup it ask to find the .exe file. What is this? When I then hit cancel, a message comes up saying it can't find the .rb file. Help please?
- kwistenbiebel
Re: Can't get started!
Welcome Jd211,jd211 wrote:Hello all! I want to start learning indigo render for sketchup pro for architecture school in the fall, but can't get it to load. I followed the instructions that were in the forum on how to load it, but when I open sketchup it ask to find the .exe file. What is this? When I then hit cancel, a message comes up saying it can't find the .rb file. Help please?
Please read the installation note carefully at the top of this thread.
Did you download the main Indigo program itself? (which is to be found in the download section of this forum). It has the needed .exe.
The .rb file is in the Skindigo download.
Wintermute
Problem using Skindigo v1.0.9
Hello
ive downloaded Indogi 1.0.9 and ive also downloaded Skindigo 1.0.9 ive followed all the instructions that ou have started in the begining and in the installation document but now when i try to render my image an error message appears saying "SceneLoaderExcep: TinyXmlWrapper: could not find element 'colour' in element 'diffuse' (around line 47)" any ideas?
Many Thanks
Many Thanks
Image not rendering
hi,
ive got over my previous problem but now i dont seem to be able to render an image properly, the image has several windows on the image but only 3 seem to be getting renderd, i have chosen the same glass in the material list to for all the windows, but t still wont work :-s any help would be greatly appreciated
Users browsing this forum: Baidu [Spider] and 35 guests
