displacement tests thread
- drBouvierLeduc
did u guys see www.crazybump.com ? this piece of software will drop ur jaws down heheh
In that case you might really be better off with instanced meshes. Especially if you're going to cover such a large terrain. Then again, it's hard to bend meshes to a terrain like this one.
But as a displacement test, of course, I find it really interesting. Maybe it's just the case that realism really depends on the map you're using...
- drBouvierLeduc
Wanted to see if displacement worked with blended material. It does !
The current preview scene is not really appropriate with that kind of material, so I replaced the sphere with a simple curved plane (the circle around the logo is where the plane intersects with the sphere).
To create the displacement map, I followed that tutorial : it's a height map based on real geometry, made in blender. It takes slightly more time than creating a map from a photography, but it's much more accurate. Though in that case, a 16bit images wouldn't hurt.
Regarding the grass, I second BbB, I don't think you can create nice-looking long grass with displacement, the leaves are too "straight". It's ok for a short grass, you know, where you play golf.
- close-up of displaced grass
- grass-closeup.jpg (76.34 KiB) Viewed 6598 times
- displacement-map used
- grid-displacement-map.jpg (57.36 KiB) Viewed 6598 times
- blended + displaced mat.
- grid.jpg (213.39 KiB) Viewed 6600 times
- drBouvierLeduc
Users browsing this forum: No registered users and 69 guests
