I guess i should make the test
split if curvature >= threshold
instead of
split if curvature > threshold
<normal_smoothing>false</normal_smoothing>
<max_num_subdivisions>3</max_num_subdivisions>
<subdivide_pixel_threshold>0.0</subdivide_pixel_threshold>
<subdivide_curvature_threshold>0.1</subdivide_curvature_threshold>
<subdivision_smoothing>true</subdivision_smoothing> Code: Select all
<displacement_map>
<uv_set>uv</uv_set>
<path>texture.jpg</path>
<exponent>2.2</exponent>
<b>0.035</b>
</displacement_map> Users browsing this forum: No registered users and 106 guests
