mandriva re-install: can i save my data before re-installing
- cheese on toast2
hello all
my HD recently messed up due to a forced shutdown and a damaged filesystem, so im gonna have to re-install mandriva on my laptop. my system will not boot, does anyone know if i can save any of my v. important files? if i do a re-install without backing up my files in the /home directory, is it definate that i will loose everything? or will it be saved? (like windows does if you have to re-install, by creating a file called windows.old)
I have vista installed on a different partition, is there any way i can transfer stuff from my home folder into the vista partition? the system doesnt get past the booting stage, but if i press esc during boot up, i enter verbose mode, so i can type any commands there.
any replies are much appreciated, and a very well done if u understood what i just said, coz i seem to have complicating things down to a fine art now lol.
- cheese on toast2
im not sure, i dont know a lot about linux, could you explain what that means and how i do it? also, here's the actual error message i get when i try to boot if this helps anything
setting hostname homewireless: [ok]
setting up logical volume management: no volume groups found
[ok]
cheking root filesystem
/dev/sda5 contains a filesystem with errors, check forced
Error reading block 33150 (attempt to read block from filesystem resulted in short read while getting next inode from scan
/dev/sda5: UNEXPECTED INCONSISTENCY: RUN fsck manually. (i.e. without -a or -p options)
***An error occoured during filesystem check.
***Dropping you into a shell.
enter root password for maintenence or press Control+D to continue
[ok]
OK, so can you enter the root pasword to get into a shell.
Then you need to run
This is the equivalent of windows chkdsk, with the added bonus that it's better
fsck /dev/sda5
- cheese on toast2
- cheese on toast2
- cheese on toast2
An external HD would be an easy and cheap solution. That's what I did. I know that there are several back up services out there but I really like the idea of the external HD better.
