beta
Post by beta » Thu May 15, 2008 12:30 am
oops ok sorry my internet is fast enough to load it in a sec. sorry i'll begin to upload them in jpeg... sorry...
Post by BbB » Thu May 15, 2008 2:35 am
No worries. We do have broadband here, but still, no point uploading images that are over a megabyte if we can have them cheaper.
Post by Zom-B » Sun May 18, 2008 6:31 am
A boring 5 Frame loop animation of the Fan @ work with some Post Processing Motion Blur, and Noise Removal:
http://www.zom-b.de/indigo/fan/
Wedge
Post by Wedge » Sun May 18, 2008 10:49 am
After talking in a topic recently http://www.indigorenderer.com/joomla/fo ... php?t=4148 I realized I have never tried to do a multi mat transparent mesh thing. One half of sphere is red and other half is green. Red half is frosted, green half is clear. So here it is:
2 glass materials on one low quality sphere mesh
Post by BbB » Sun May 18, 2008 11:23 am
Pretty cool
tungee
Post by tungee » Mon May 19, 2008 5:34 am
Wow the fan looks very cool!
Wedge
Post by Wedge » Tue May 20, 2008 12:52 pm
I set up a little studio this time. Made a quick dog. Material is glass, emitters inside, gave it thickness (it has two layers).....
I stopped it at 15 hours or so...didn't like the result. I would like to try bidir and change lighting to see if more caustics will show up. Also I will remove multi material as it did not work out like I wanted it to.
So this was only a quickie model but I thought it was worth posting. Boolean operations I used to put the pieces together ended up destroying the mesh. It has errors all over it and that is probably why some of the areas look funny. Also the double layer may be causing some trouble. :)
Studio shot with glass dog
cookieofdoom
Post by cookieofdoom » Fri May 23, 2008 3:34 am
Studio setup sort of thing. I made the box texture in GIMP My U/V mapping could be a bit better around the edges, but it was just something I threw together real quick 'cause I was bored and Hardy had just come out. I think I'll make the light color less intense next time. I love that tutorial on studio setups, though. It taught me a lot about how to do this kind of thing.
Just something I threw together.
rgigante
Post by rgigante » Fri May 23, 2008 3:56 am
Here it goes! Tristicks...
Regards, Riccardo.
Johan
Orange Tree
Post by Johan » Sun May 25, 2008 2:51 am
This was my first testrender using Indigo. The glossy reflections is by far the best I´ve seen.
Compared the scene using Fry Render and Maxwell.
The first "main" reason for me to test Indigo was there is no support for 3dsmax 2009 yet, in other unbiased render engines. I had to use an old version of c4d to render in Fry and Maxwell.
Iam testing the workflow between Revit 2009 and 3dsmax 2009. Hence why I really need 3dsmax 2009. Cad link works ofcourse like before, but Iam testing the new fbx export/importer.
Happy to be here.
Cheers
Johan Sae-Thao
Stur
Post by Stur » Sun May 25, 2008 7:25 am
Nice picture, I like it.
zsouthboy
Post by zsouthboy » Sun May 25, 2008 8:34 am
That render is most zen. A feeling of wholeness.
Very nice :)
Johan
Post by Johan » Sun May 25, 2008 9:19 pm
Zen? hehe yeah I would guess, since it´s in my character.
Peace all
Johan
Qwaszt
Greeny
Post by Qwaszt » Tue May 27, 2008 9:46 pm
Hi all my first green vegetation test.
Well almost everything belongs to BbB (again thank you very much), trees, grass and water bump map.
But still i had to give it a go, and also a first try with the well known ivy-generator.
Maybe someday this will lead to something...
Qwaszt
Post by Qwaszt » Thu May 29, 2008 5:44 am
And my first night test.
Lights are difficult to set, i think. I am still not sure how to use the efficacy scale. But a lot of trying and testing will eventually lead to something.
One question though:
The "Max depth" parameter is also of influence of the power of the lights?
Because when i set them really low (i.e. 50) then the green lights under water won't spread as far as when i set the max depth at "1000" , which was the setting in the posted picture, but then i had to lower the power of the lights otherwise the lights would be blinding bright.
Anyway on to something new.
Users browsing this forum: No registered users and 156 guests
