Trees, grass, rocks, free goodies and fireflies...
Post by BbB » Mon May 19, 2008 7:47 pm
I was playing with the time-limited trial version of XFrog the other day and I came up with these: A small citrus tree and a parody of an oleander, which I both needed for the bigger scene (more about this one when we get the shift lens).
I've also made a patch of grass which can be used as instance to cover large areas. It's better than alpha planes if you want to render your scene from different angles, and it's not much heavier polywise. Finally I added a few rocks for fun.
I've decided to release all these model in the attached archive. It includes both trees, the rocks, the grass and all the required texture maps (the oleander is not mapped, only the citrus tree). Not included is the surrounded building and ground. The maps are not all mine, so please don't go around redistributing them. Otherwise, feel free to use the models as you please.
As you can see, I suffered a big firefly attack here. So I decided to take a break and re-render the full scene as soon as Ono has fixed that problem (If that helps, I used pathtracing only here).
That's it. Enjoy.
TreesBlendFile.zip
(1.74 MiB) Downloaded 379 times
TreesObjFile.zip
(2.2 MiB) Downloaded 372 times
TreeMap.zip
(3 MiB) Downloaded 400 times
vux
Post by vux » Mon May 19, 2008 8:19 pm
Try Maya PaintFX :wink:
If you dont know what it is - see flora in "Shrek" :lol:
Post by Pibuz » Mon May 19, 2008 9:26 pm
Thank you Bbb: you're so kind!
**EDIT**
..sorry to bother, but i've just seen that the uncompressed obj is something like 15MB, and it seems quite impossible for me to import in SU :wink: ..
..so...would you be so kind to post the grass obj only?
Post by BbB » Mon May 19, 2008 9:37 pm
Sure Pibuz.
Grass.zip
(283.99 KiB) Downloaded 407 times
dougal2
Post by dougal2 » Mon May 19, 2008 10:06 pm
Sorry, for slight OT, but...
vux wrote:Try Maya PaintFX
Have you had success exporting this to indigo ? I know it's possible by converting to geometry first, but how do you deal with the shaders ? I find most of the colour detail gets lost.
Reply in the Maya forum if you wish ;)
Post by CTZn » Mon May 19, 2008 11:09 pm
Colours in pfx are ramps and iff texture files. Indigo takes none of them, you need to export the texture yourself (including alpha maps from iff for null blend).
Post by BbB » Mon May 19, 2008 11:11 pm
Try Maya PaintFX
I'd have to own Maya. And then I'd have to learn it ;-)
Post by Pibuz » Tue May 20, 2008 12:04 am
Thank you Bbb for your grass patch! :D
vux
Post by vux » Tue May 20, 2008 12:54 am
dougal2
I just convert shader to texture (software render) and than correct in Shop;)
vux
Post by vux » Tue May 20, 2008 1:16 am
hey dougal2 hoe to make materrials with alpha???
in Blendigo I dont had a problem :oops:
Post by suvakas » Tue May 20, 2008 1:20 am
Nice plants! Will have to check out the Xfrog stuff more seriously. Havn't really used 3D trees in my work very offten.
dougal2
Post by dougal2 » Tue May 20, 2008 1:21 am
vux
This is OT, I'll start a thread in the Maya forum.
Post by BbB » Tue May 20, 2008 2:03 am
Xfrog trees are good. But the ready-made ones often need serious poly reduction before they're usable.
Qwaszt
Post by Qwaszt » Tue May 20, 2008 8:40 am
Thanks alot BbB, for the downloads!
I dont know if this is someting but maybe it is worth checking out.
I was posted on blendernation today and i am going to give it a try but maybe others might think this is an interesting link too?
Anyway here it is:
http://yorik.orgfree.com/tutorials/treemaking.html
zsouthboy
Post by zsouthboy » Sun May 25, 2008 4:52 am
Bertrand,
I finally got around to trying out your (as usual) beautiful trees and grass that you've graciously released.
Problem - some of the leaves reference a texture that is not included in the texture pack you uploaded with them - "LeavesTropical0131_2_S" and "B"
Oh and the flower textures - I can see them referenced in blendigo, but they're not included.
Can you make that available? (If not it's quite alright :))
Users browsing this forum: No registered users and 199 guests
