IES Pack
dougal2
Post by dougal2 » Wed May 14, 2008 4:29 am
The result you see in my render above is from using a very small plane with it's normal pointing in the direction of the light - in this case downwards.
If you could let us know what 3d app you use, I'm sure someone here can talk you through how to set it up.
dougal2
Post by dougal2 » Thu May 15, 2008 5:56 am
OK, I've rendered the whole lot. 2475 are compatible with indigo.
Anyone got any good ideas on how to display/distribute the renders? they total about 233mb.
Post by CTZn » Thu May 15, 2008 6:22 am
batch convert, generate page with links to images. Apache style.
dougal2
Post by dougal2 » Thu May 15, 2008 6:26 am
frankly, I can't be bothered. I'm gonna just package them up as a zip and post a link here.
EDIT: http://www.ftlfm.com/doug/Lithonia_Ligh ... eviews.zip (30.1mb)
Post by BbB » Thu May 15, 2008 8:35 am
Thanks Dougal. Much appreciated. And thanks to Pibuz for the goodies.
dougal2
Post by dougal2 » Thu May 15, 2008 11:58 am
No problem, I'm glad I could give my machine a decent job to do ... so many wasted CPU cycles ... :)
roville_csb
Post by roville_csb » Thu Jul 17, 2008 2:18 am
Hi! guys is it possible to change the color of the ies light?
Post by BbB » Thu Jul 17, 2008 2:52 am
I think I've done that successfully in the past, but don't quote me on it...
Post by Kram1032 » Thu Jul 17, 2008 5:52 am
afaik, IES lights don't include frequency data, just how strong the light goes where.
So, simply using RGB / Blackbody light in the desired colour should work fine.
Post by StompinTom » Thu Jul 17, 2008 7:07 am
use a very small plane with an Emitter material and load your IES profile into that. remember, Indigo doesnt have "lights" per se, but rather any object can emit light.
using a tiny plane is the most efficient way, though, because Indigo projects the IES profile from a point at the center of each face, in the direction of the face normal. so for a single IES light, you just need one face, therefore a plane.
hopefully in the next release or two there will be a more comprehensive support for all kinds of IES profiles as well as linear IES lights, etc etc.
SpAcEtRiBe
Post by SpAcEtRiBe » Tue Jan 20, 2009 8:23 pm
can someone reupload ies archive? i can't download it...
Post by CTZn » Wed Jan 21, 2009 3:57 am
SpAcEtRiBe
Post by SpAcEtRiBe » Wed Jan 21, 2009 8:16 pm
sorry... i mean the one with preview... the last posted by dougal2
dougal2
Post by dougal2 » Thu Jan 22, 2009 12:26 am
I still have that file in a backup. If someone can host it, I'll give it to them to host.
Post by PureSpider » Thu Jan 22, 2009 1:04 am
What size is it?
