Exterior
Exterior
A few images I did recently. Trying to work with buildings and vegetation. The trees, the plants and the car are free models from the web. The rest is Blender. Let me know what you think.
- im1210005425S.jpg (239.73 KiB) Viewed 16300 times
- Villa.jpg (237.25 KiB) Viewed 16300 times
- VillaB.jpg (309.27 KiB) Viewed 16300 times
- aleksandera
- joegiampaoli
Thanks guys.
Aleksander: Yes, I forgot to put a plane under the big building so there's no floor and the sky system is radiating light upwards. Silly me.
Most of the small plants are from Evermotion.org. They have free models for each of their model DVDs and I grabbed quite a few nice-looking plants there.
The link for the car was posted here a while ago. Can't remember on the top of my head. Let me try to find it.
- Phr0stByte
damn! that vegetation is retardedly good! especially the grass. are those alpha planes?
the plants above the gate seem to be floating in the first shot, maybe if the edge of their planter was somehow defined a bit better? slight burning in photoshop could do it!
thats a very daring cantilever
but these days they can build anything! a bit more detail (subtle texture? the odd stain or crack?) on the cantileverd floorslab might be nice as it is pretty prominent.
awesome stuff as usual, man! keep it up
- PureSpider
Cheers Phrosbyte, Kram,
StompinTom: The grass is mesh. It's a round patch of grass in 3ds format I found here (basically a repository of all free plant models on the web - they also have quite a few nice trees and plants).
I applied a grass texture to it and instanced it about a dozen times and moved it around to break the repetitive pattern. There's also a diffuse, grass-mapped plane underneath.
The inspiration for the house comes from here. You're right about the texture. Right now the walls have a bump map, but they still look a bit too uniform. I must get my hand on a slightly textured off-white stuccoed or plaster wall map.
PureSpider: Good point. The place should actually be Japan. I found the licence plate in one of the car models I downloaded in the past. It was the only one that worked for me
[/url]
[/url]
