Trees
Trees
Post by OnoSendai » Sun May 04, 2008 2:22 pm
I noticed in another thread that you can get the XFrog Sweet Birch model for free from TurboSquid. So I decided I would do some tree rendering.
In the process of making the render I've found several bugs/issues :)
I've also changed the way null materials work in order to make alpha mapping converge faster.
The leaf material is a diffuse transmitter / phong blend (then all blended with null for the alpha mapping)
I'll make a short tutorial for setting up this material as I think it's a core material technique that all Indigo users should understand :)
hafunui
Post by hafunui » Sun May 04, 2008 4:50 pm
Wow, this would look even better with volumetrics :)
Gotta see that tutorial, maybe this would work for billboarded grass renders.
Post by OnoSendai » Sun May 04, 2008 6:42 pm
another one..
Post by suvakas » Sun May 04, 2008 7:30 pm
Time stamp? A new feature ? =P
Post by OnoSendai » Sun May 04, 2008 7:34 pm
yup :)
Post by suvakas » Sun May 04, 2008 9:06 pm
Nice !!! 8)
Post by BbB » Sun May 04, 2008 9:39 pm
Oh that's going to be very useful.
Ono, could you do me a big favour? This model is very simple. Too simple for realistic scenes. Could you try this with one of the trees here:
http://graphics.uni-konstanz.de/plantslib/main.html
... and just repeat what you did (some of the trees do no need an an alpha map - a three-way blend mat - as the leaves are actually modeled, just a blend of diffuse/trans and phong).
I've seen some very serious slow-downs in rendering due to lots of leaves and am curious as to what you come up with.
Post by OnoSendai » Sun May 04, 2008 10:43 pm
nice.. I'll try the plum tree.
Post by BbB » Sun May 04, 2008 11:04 pm
Are your leaves upside down by any chance?
Post by OnoSendai » Sun May 04, 2008 11:07 pm
They certainly don't seem to correspond to the branches in the images I posted, that's for sure :)
Post by BbB » Sun May 04, 2008 11:18 pm
That tree's not that bad actually. But definitely one for the background. Looking forward to seeing what you come up to with these other ones.
Post by OnoSendai » Sun May 04, 2008 11:19 pm
This is the purple leaved plum.
Sadly the obj tris aren't divided up properly by usemtl elements, so I'll have to do some surgery on the obj first.
Post by BbB » Sun May 04, 2008 11:24 pm
I used this one in my exterior times of day pic and it worked fine... Weird.
Post by OnoSendai » Sun May 04, 2008 11:26 pm
Did you use the .obj directly tho?
Post by OnoSendai » Sun May 04, 2008 11:32 pm
Ok, surgery done.
UV coords on the trunk looks kinda screwed tho.
Users browsing this forum: Google [Bot] and 43 guests
