Lighting help wanted.
4 posts • Page 1 of 1
JDA
Post by JDA » Tue Apr 22, 2008 11:30 am
Hi!
I'm doing a tutorial and needs some
help with the lighting part of the tutorial.
Now you might say " why are you doing a tutorial
if you don't understand lighting in Indigo?"
Well you see I do to a point.
Ok so here's the deal...
Image 1 has 2 mesh emitters.
Notice how dark the top area of the image is.
Image 2 is covered with a cube with the bottom
removed. The 5 faces of the box emit light.
It gives nice uniform lighting but lacks highlights.
Now when I combine the 2 lighting methods
I don't get the uniform lighting.
The render always ends up like Image 1.
So my question is... How do I get the best of both worlds?
And before you say Violet I have tried that and I didn't get the results
I am looking for. So either I don't know what I am doing or Violet is not the answer.
Image 2
Image 1
Post by pixie » Tue Apr 22, 2008 12:30 pm
Combine both and give more strenght to those two meshes, another suggestion would be using other tonemapping but reinhard.
Post by Kram1032 » Thu Apr 24, 2008 10:01 pm
Maybe, you could add a third filllight to compensate the darker area instead of illuminating the domino....
dougal2
Post by dougal2 » Thu Apr 24, 2008 10:50 pm
Or simply adjust the power of your lights so that the lights in 01 are stronger?
Or, make the meshlights in 01 smaller so that they are more like "point"/"spot" lights = stronger highlights.
(BTW, 02 could be simulated by simply using Background colour environment lighting - it's perfectly uniform)
Users browsing this forum: Ahrefs [Bot] and 44 guests
