Exterior - times of day
ousmee
Post by ousmee » Thu Apr 17, 2008 2:10 am
First go to arroway (http://arroway.de/textures/05/en/index.html) and download the sample texture for "stone 43" (in "classic stones"). That's the one I used.
The settings were as follows:[/quote]
Pibuz: Can you relate this in Su format too :D for dis newbie
Post by Pibuz » Thu Apr 17, 2008 2:23 am
You want me to translate the parameters in "skindigo language"?
ousmee
Post by ousmee » Thu Apr 17, 2008 2:33 am
Yes, please if it won't b too much trouble but no rush sha. I can always wait
Post by BbB » Thu Apr 17, 2008 3:23 am
Hi Pibuz,
1_I see the R,G,B values are less than 1: did you apply a sort of desaturation?
The albedo texture overrides the RGB values so they don't matter here.
2_The A and C values of the exponent map are default?(i assume the B value controls the exponent value admitted for the white pixels)
Yes, the A value is the default value. Not too sure what it does to this day. The C value does control the exponent of the white pixels, although Blendigo caps it at 10,000, which I'm not sure was intended. C is for the black pixels. I set the gamma at 2.2 since it's set at 1 by default.
3_The indigo mat "GLOSSY+METALLIC" is a preset, or a brief explaination of what a PHONG shader is?
Just a brief explanation AFAIK
s!m
Post by s!m » Mon Apr 21, 2008 3:15 am
impressive work and thanks for sharing the stone texture...
Would you mind sharing your water texture as well? ;)
Thanks in advance...
Post by BbB » Mon Apr 21, 2008 7:06 am
s!m
Sure. The water map is mine so I don't mind sharing it. It's not on this computer, though. I can upload it tomorrow.
ousmee
Post by ousmee » Tue Apr 22, 2008 1:36 am
Hi PIBUZ:
Was away for somedays. here is a shrub I tried out you little tutorial with and it came out well though partially rendered its without the black.Don't mind the shade huess its the postioning if you look carefully the leaves are jus fyn.
So, so, so, GREATFUL! :-)
Post by Pibuz » Tue Apr 22, 2008 4:10 am
@ ousmee
Once you've fixed the black leaf area issue, you could demonstrate your gratefulness by sharing the skp model :wink:
Post by BbB » Tue Apr 22, 2008 6:12 pm
Here's the water texture
Water.zip
(1.96 MiB) Downloaded 234 times
Post by Pibuz » Tue Apr 22, 2008 8:11 pm
Thank you for the bump map Bbb!
I've some problems finding proper water bump textures: con you suggest me a site, or post some of your favourites, or teach me how to make my own?
Post by BbB » Tue Apr 22, 2008 8:38 pm
I made this one myself using several images from cgtextures.com
They have a water section, though not all the images are really useable.
You're right, good ones are really hard to find.
One option, I imagine, would be to use Terragen 0.9 (or 2), create a water plane and render it with the camera pointing straight at it from above.
Post by Pibuz » Tue Apr 22, 2008 9:48 pm
Oh..
Thanks however! :D
Post by BbB » Tue Apr 22, 2008 10:26 pm
As far as teaching, I'm not sure there's anything to learn really.
For this map, I downloaded lots of water photographs and pasted them like a patchwork in Photoshop, trying to smooth the seams.
Then I desaturated the image and applied a Highpass filter to get rid of the highlights.
Now that I think of it, I'm sure Terragen would be a better way, though. I'll give it a try some time.
s!m
Post by s!m » Tue Apr 22, 2008 10:44 pm
Thank you very much for the texture... :)
ousmee
Post by ousmee » Wed Apr 23, 2008 1:28 am
Hey, BbB its great when I realise you guys are out there just downloaded the texture too.
Users browsing this forum: Google [Bot] and 61 guests
