Sun Position Calculator
GNUdo
Post by GNUdo » Sat Apr 19, 2008 4:45 am
I just uploaded a new version with:
# added check to handle wrong sunrise and sunset because of wrong TZ
# the "Now" button sets the current timezone
# added animation support
Could someone test if animating works as expected?
Usage instructions are in the script Info section.
Download the script from the first post.
Thank you
neepneep
Post by neepneep » Sat Apr 19, 2008 6:35 am
That was quick! :shock:
And the animation seems to work very well!!!!!
However the one thing that may need changing is the interpolation type - it should be linear by default so the sun movement is constant.
Here's a really quick Blender render test - a 3 hour time lapse of a late afternoon sun compressed into 4 seconds.
edit: changed my mind :D the current default is fine as it is :roll:
Suntest.zip
(87.86 KiB) Downloaded 240 times
