white balance settings for fluorescent light ?
4 posts • Page 1 of 1
delic
Post by delic » Thu Apr 17, 2008 8:31 pm
Which white balance setting for fluorescent light should be the best ?
In most cameras you can have a fluorescent light setting, sometimes called H.
I guess E is the best in many cases, but is there a setting that could be better for this ?
:idea:
alexmeyer
Post by alexmeyer » Fri Apr 18, 2008 1:12 am
Save an IGI file with your render, and just screw around in Violet to see what works best.
dougal2
Post by dougal2 » Fri Apr 18, 2008 1:17 am
it depends on the temperature of the light source too.
Usually fluorescent lights look slightly blue, so choose an emitter temperature which is slightly higher than the camera white balance.
ie: emitter at 7000 or 7200 K
and choose D65 (6500K) white balance.
you'll have to tweak the values to taste.
delic
Post by delic » Fri Apr 18, 2008 2:11 am
Thx, I'll try ...
